Polyline joints pointed not clean
Message 1 of 21
I am trying to join polylines and arcs, and polylines to other polylines. The joints have these pointed corners and I can't figure out how to make them nice smooth corners. The attached jpg is of my problem.
I can make them smooth by leaving all the plines separate and extended them to create a clean look, but I would really like to be able to have the clean look with all the plines joined together.
Replies (20)
Message 2 of 21
Alfred.NESWADBA
looks like the segments of the polylines do have different widths, but to be sure we need the DWG, not a screenshot from that.
What you can try: select one of the polylines, and within the property window change the "global width" and see if the display changes to a better one.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 21
Alfred,
I can not share the file without a signed NDA. In the jpeg both the straight Pline and arc both have a the same global width. I need to join the arc and pline together to be able to change with global width of the arc. Once joined the joints look like so instead of a smooth transition.
Message 4 of 21
Alfred.NESWADBA
Create a new drawing, copy one polyline with 3 segments (showing the display issue) into the new drawing ... will publishing of that new drawing be critical?
- alfred -
Alfred NESWADBA
Message 5 of 21
SeeMSixty7
I was looking at this thinking plinegen would resolve it, but it just acts odd.
Here is a sample drawing I made. Notice the odd connections. I don't recall this behavior in older versions (this is 2017).
Message 6 of 21
Alfred.NESWADBA
Sorry, nothing attached.
- alfred -
Alfred NESWADBA
Message 7 of 21
pendean
Community Legend
Community Legend
Does this happen if you start a new drawing?
What is PLINETYPE set to? 2 here, otherwise I can't replciate your issue either.
Message 8 of 21
SeeMSixty7
DOH!  Here it is.
Message 9 of 21
When starting a new file I get the same joints. I have tried Pline types 0, 1 & 2 and they all give me the same result.
I am working in AutoCAD 2012 so I can not open the file previously attached.
Here is a sample file out of my CAD. It was a new file and I only drew an arc and a polyline, joined them together and changed their global width. I'd like to get a corner that looks like the one of the 2 polylines joined together but when I am joining an arc to a polyline.
Message 10 of 21
pendean
Community Legend
Community Legend
>>>..., joined them together...<<<
Method was...?
Message 11 of 21
The join function.
Thank you,
David Johnson
Mechanical Design Engineer
Molex Printed Electronics Division
8647 Eagle Creek Pkwy
Savage, Minnesota United States
Direct: 952-846-6973
Mobile: 651-728-1034
Email: dave.johnson@molex.com
www.molex.com
[email signature logo]
Warning - Information included in this email and /or in any attachments herein may be subject to the EAR (15 CFR 730-774) and/or ITAR (22 CFR 120-130) Regulations.
The recipient acknowledges their responsibility for compliance with all Export Administration Regulations & ITAR regulations regarding the handling and/or export of any Molex products and technical information; including the disclosure to any Foreign Nationals
________________________________
CONFIDENTIALITY NOTICE: This message (including any attachments) may contain Molex confidential information, protected by law. If this message is confidential, forwarding it to individuals, other than those with a need to know, without the permission of the sender, is prohibited.
This message is also intended for a specific individual. If you are not the intended recipient, you should delete this message and are hereby notified that any disclosure, copying, or distribution of this message or taking of any action based upon it, is strictly prohibited.
English | Chinese | Japanese
www.molex.com/confidentiality.html
Message 12 of 21
Alfred.NESWADBA
>> DOH!  Here it is.
Thank you!
The drawing now shows different situations, one situation is for straight segments with angles less than 29° ... they will not be shown as filled, that was always the same, I guess to avoid long, long peaks from the corners.
The situation/transition between straight segment and curved segment seems to be a bit more tricky (from the point of mathematical view). But sorry to say, without assigning different segment widths to the straight segment and arc segment I can't get this type of corner working with a constant polyline-width.
- alfred -
Alfred NESWADBA
Message 13 of 21
SeeMSixty7
Dont let my drawing detract from the OP. I was just trying to provide a drawing file for everyone to see the issue. Mine is over exaggerated. I'm with you. I believe a plane segment with varied widths is the answer.
Message 14 of 21
Kent1Cooper
@Anonymous wrote:
I am trying to join polylines and arcs, and polylines to other polylines. The joints have these pointed corners and I can't figure out how to make them nice smooth corners. ....
I believe that is just in the nature of Polylines with width where a line segment meets an arc segment non-tangentially.  If you can, put short tangent line segments on the ends of the arc segments before the bends.
Kent Cooper, AIA
Message 15 of 21
This is the way I had been doing it joining originally. I was hoping to be able to join an arc to a non tangent line and have a nice corner, but it seems that the math behind it is too complicated and forces me to do it this way.
Thanks for all the replies everyone.
Message 16 of 21
My solution in this case is: choose the vertex - intersection between line & arc segments, then add a new vertex, move the new vertex into old intersection, and see the result.
Message 17 of 21
tim_crouse
I realize this is an old thread but this answer may help a few folks out, s0 goes:
1. Key Point - You have to remember that pline end types and joint types are not an object property and are to be defined in the plot config file.
2.  Setting the end type to ROUND and the Joint type to MITERED will do a pretty good job of removing pline joint openings that occur at angled joints.
Hope this helps a few folks out
BBest Regards
-Tim C.
Message 18 of 21
gmartic
Community Visitor
Community Visitor
When making pline end pline with 'close'. If pline has thickness all corner will be sharp.
Message 19 of 21
jameslammu
I believe one option is to ensure the line width is 0 the offset with another line at the with you want - keep both lines.
then add a hatch fill - make sure the both plines are closed
Message 20 of 21
dbanaszak
Already set as you mentioned.
