2018 New Knowledge Network Solutions | AutoCAD
matthew.d
Alumni Alumni
matthew.d
Question: Where can I find a list of the latest Autodesk Knowledge Network support solutions that were created and/or updated regarding AutoCAD?
 Subscribe to receive updates for new Knowledge Network articles on AutoCAD.
For more updated solutions, also check out the Autodesk Blogs!
2016 Solutions 2017 Solutions
Matt DiMichele
Autodesk Product Blogs | @ADSKCommunity Twitter
Likes are greatly appreciated. Everyone enjoys a thumbs up!
Please Accept As Solution if this resolves your issue, to help others benefit and locate it.
matthew.d
June 2018
FBXIMPORT and FBXEXPORT removed from AutoCAD 2019
AutoCAD Web functions are not available
How to export points from a block in AutoCAD
Licensing Error: “Establish an Internet connection to continue” due to the licensing security hotfix
Objects in Xref or in a drawing do not display at all or incorrectly in AutoCAD
Annotative Hatch Rotation in Viewports Varies
AutoCAD pulls a Product Design Suite license when AutoCAD seats are available
AutoCAD: How to automate the PDF exportation for several drawings using a Master DWG file
AutoCAD: Protect drawings from editing or copying by 3rd party
AutoCAD®: Missing nested raster image when inserting it from a block
Autodesk Drive : Unable to create folders in drive
Block geometry with color set ByBlock displays wrong color in viewport in AutoCAD 2019
Bringing KML/KMZ files into AutoCAD
Can not select or display layout tab geometry in AutoCAD
Error: “At least one of the specified xrefs failed to bind due to a problem with a proxy object.” wh...
Error: “failed to load acdeployui.dll (193)!
Error: “Revit could not create a local file from BIM 360” when opening a Revit collaboration model
FILLET command applies to wrong end of spline in AutoCAD
Filter command not selecting objects correctly in AutoCAD
How to change Enterprise CUIX and add new Menu from workspace
How to change the Image of a tool on a Tool Palette
How to determine which drawing files an Xref is attached to in AutoCAD
How to extract MSP files from EXE updates
How to print a table in AutoCAD with the column and row header information
Licensing Error: “Establish an Internet connection to continue” due to automatic configuration scrip...
Licensing Error: “Establish an Internet connection to continue” due to firewall security settings
Licensing Error: “Establish an Internet connection to continue” due to internet proxy server configu...
Mac Freezes at Serial Number Entry
Placing Views on Sheets in Sheet Set Manager takes a long time in AutoCAD
Red hatch gap circles don’t show in AutoCAD 2019
Slow performance in AutoCAD-based products when using many hatch definitions placed in a network loc...
Switching between layouts in AutoCAD 2019 changes the draw order of objects
Unable to use XOPEN command in AutoCAD 2019
Uncompressed textures cannot be activated in the Graphics Performance of AutoCAD
When opening a file you receive a Fatal error; unhandled access violation reading 0x002c, exception ...
Inserting a block containing a wipeout in AutoCAD 2019 moves the wipeout above other objects
You want to know if its possible to have multiple versions of Autodesk software installed on your co...
Equipment shifting and overlapping when exporting a P&ID drawing from AutoCAD Plant 3D
How to delete a layout tab
Properties palette is missing a section in AutoCAD
AutoCAD : How to edit same drawing file by multiple users
AutoCAD crashes after installing updates KB4088875, KB4088878, KB4093118 and KB4093108
AutoCAD freezes while executing LAYDEL command
AutoCAD: Polygonal viewport when on a “no plot” layer still shows up black when plotting
Automatic save takes a long time in AutoCAD
Civil 3D: When he tries to reopen file the work is gone
Copy/Paste basepoint incorrect for arcs in AutoCAD 2019
Error 1606. Could not access network location during AutoCAD deployment installation
Error: “Exception in acexperience.arx ARX Command” when starting AutoCAD
How to control line weight of multiple objects via lisp
Multiple users can open the same DWG file in AutoCAD over SharePoint
Sheet Set Manager project fields populate with previous project’s information in AutoCAD
May 2018
AutoCAD 2019: Polygonal Viewport and polygonal VPClip turns off raster image with Transparency appli...
AutoCAD products: .bak files are not created and drawings cannot be recovered
AutoCAD: eTransmit displaying Transmittal creation failed error message
AutoCAD: Save window not showing up
AutoCAD: Trouble importing CTB Plot Style file
Cannot apply plot transparency to some objects but not others in AutoCAD
Insertion of a datalinked table in AutoCAD does not display anything
Objects disappear after being selected during the ARRAYRECT command
Publish individual PDFs for each layout
Some toolbar icons display as a cloud and question mark in AutoCAD 2019
Update 2019.0.1 available for AutoCAD and AutoCAD LT
You copy a block in AutoCAD 2019 and the included hatch is shown in the front
3D content in drawing file displays as blown apart in AutoCAD for some users
Does AutoCAD automatically check for updates and install them automatically
Flatshot block placed at incorrect orientation
Navisworks: Objects from Plant 3D file are white
No downloads available for Mac AutoCAD products
Cannot open sheet set created in a previous version of AutoCAD
How to create contour lines from ascii file in AutoCAD
A360 Desktop crashes upon computer startup
AutoCAD does not respond waiting for svchost.exe process in Resource Monitor
AutoCAD drawings appear empty when opened in BobCAD
AutoCAD: Change all text to Caps
AutoCAD: Turn Off Image Border
AutoCAD: XREF - Attach or Overlay?
Error: “ActiveX and some proprietary components cannot be imported” while linking or importing a DWG...
Graphic problem: Some components are not visible
Hatch objects disappear when drawing is opened or block is inserted in AutoCAD
How to download a complete Autodesk software installation package
Every other day AutoCAD is asking for reactivation.
April 2018
Tolerance text is the wrong size in AutoCAD
Unable to obtain network license, FlexNet License Finder dialog appears
When using the distance command, the dimension will increase drastically when hovering over a line i...
Which graphic cards are certified and recommended for AutoCAD-based products?
White hatch with transparency plots grey or black in AutoCAD 2018
Mouse pointer does not line up with crosshairs when working in 3D in AutoCAD
Plotting viewport with “Rendered” visual style to PDF is putting glitches in the image
Running AutoCAD on vCloudPoint
Some ribbon tabs missing from AutoCAD 2016 after installing AutoCAD 2019
Not seeing options to control the ARRAY command in AutoCAD
Problems with the performance of AutoCAD 2018 on VMWare
Error: Import Failed
Find and replace search results cannot be sorted alphabetically
Licensing error when running AutoCAD 2019 trial
Get Up to Speed: AutoCAD 2019
HATCH command creates incorrect or inaccurate hatch areas when picked by internal point in AutoCAD
Excel tables insert with different cell widths than are expected in AutoCAD
Hatch icons are showing as all black in AutoCAD
Hatch lines are invisible in xref file
How to turn off layers in your AutoCAD PDF Plots
Licensing error when starting AutoCAD 2019
Network license only launches when running as an administrator
Only One AutoCAD FAQ
Time in the AutoCAD properties when transfering date value from Vault
Unable to create or edit views in a drawing using VIEWBASE and VIEWEDIT in AutoCAD
Unable to print to scale in AutoCAD
Update 2018.1.2 available for AutoCAD and AutoCAD LT
When viewed in the Windows preview pane, DWG preview images are distorted
When working with attached point clouds there is always a snap to suggested planes of the point clou...
Crashing with third party application East Coast Cad in AutoCAD
Dimensions sometimes have Asian characters
Drag and drop from Windows File Manager to AutoCAD is not working
Error 1336 when uninstalling your Autodesk Software
Objects do not print in drawing from AutoCAD
COMPARE command does not work properly with AutoCAD Architecture or AutoCAD MEP objects
Error: “1 data link(s) do not allow their data to be written out.”
How to move an attribute separately which is part of a dynamic block?
Trouble with Linux thin client using AutoCAD from Citrix server
When moving blocks with an Xclip boundary, the rest of the geometry shows in AutoCAD
AutoCAD: “You do not have permission to save to this location. Contact your administrator to obtain ...
Can’t rotate and orbit 3D model in all directions
Circles are not showing as round in AutoCAD
Can Navisworks files be opened by AutoCAD
Autotostack fractions do not remove lading space in AutoCAD 2019
Bad appeareance in created PDF of 3D blocks which are plotted with Shade Plot “Hidden”
AutoCAD 2017 not lunching with a borrowed Building Design Suite Premium license.
AUTOCAD 2019 - german command DEHNEN not available any more for localized version
AutoCAD 2019 is closing unexpectedly with Fatal Error when opening a drawing from AutoCAD 2017
AutoCAD 2019 Trial - Error “The license manager is not functioning or is improperly installed.”
AutoCAD and Revit are slow with Lumion third-party application
AutoCAD eTransmit excludes unloaded xrefs which are set to “no path”
AutoCAD freezes and can’t select anything immediately after opening
AutoCAD Freezes when running Save As or opening external references
AutoCAD LT 2019 Fatal Error on startup
AutoCAD performance lag after installing Windows 10 Update 1709
AutoCAD: My leader is not working as in other drawings
AutoCAD: Thumbnails not showing in Design Center
.NET is not installed. AutoCAD LT 2007 cannot not be installed without this component.
“Error applying transforms” when installing or uninstalling Autodesk products
AutoCAD Error - Corrupted pre-install
AutoCAD issue when modifying Associative Array Items
How to adjust DWF or PDF precision settings in AutoCAD
Navisworks displaying object colors different than AutoCAD
When plotting from AutoCAD to very small increments and zooming to 6400% in adobe, some lines do not...
Autodesk Desktop App is unresponsive
How to start AutoCAD with a certain tab in ribbon
Publish fails with the message ‘errors found’ and no PDF is created in AutoCAD
Fatal error when using NWCOUT command in AutoCAD
HPDRAWORDER resets to 3 in AutoCAD
Selection and mouse movement is choppy after moving to a layout and back to model space in specific ...
AutoCAD 2019: Xref’s name reverts from Uppercase to Lowercase after it’s renamed in Windows explorer
Error: “Unable to load profile file” when launching AutoCAD
External references attached with URL paths do not display in AutoCAD
Fabrication CADmep 2018 graphical and performance issues
Inaccurate translation when executing CHAMFER (Command) in AutoCAD French
Installation error: A newer version of Material Library is already installed (error code: 1603)
Objects do not move smoothly in AutoCAD
Parallels Desktop Not Found
Unable to delete “$AUDIT-BAD-LAYER” layers
March 2018
Text stays horizontal when being rotated in AutoCAD
Trouble selecting points and lines with the cursor
Your computer shut down when you trying to activate AutoCAD.
AutoCAD 2017: Drawing created in AutoCAD 2018 and save down to 2013 version shows hatch anomalies
AutoCAD 2018 : AutoCAD freezes while using APPINT command
Run Performance Tool show error message
Mouse movement and other commands lag in AutoCAD 2018
Not possible to migrate the custom ToolPalette location from 2017 to AutoCAD 2018
Problems pulling licenses with a combined AEC and perpetual license.
Mirroring a hatch does not maintain the origin point in AutoCAD
DWG files saved in Inventor cannot be edited in AutoCAD
Error “The License manager is not functioning or is improperly installed. AutoCAD LT will shut down ...
Freeze when trying to draw a dimension in AutoCAD
AutoCAD® : How to run a script from a custom toolbar button
AutoCAD opens when the machine is first started but is unable to be reopened after closing
Cannot copy named views between drawings in AutoCAD
Certain files take a long time to open on some machines, but work fine on others
DWG file type association to a specific version of AutoCAD on Windows 10
FBXIMPORT does not bring in any geometry in AutoCAD
Hidden lines setting on the detail views on paperspace
How to print multiple sheets at once from modelspace in AutoCAD
How to use Autodesk software with trial license
It is not possible to print on plotter HP DesignJet 1050C on Windows 10 system
Loss of dimension associativity in paperspace
Mirroring a block mirrors its hatches
PDFs attached as XRefs slow down AutoCAD
Using osnaps in paper space causes points to default to the center of viewbase views in AutoCAD
Warning: “Windows is searching for acad.exe” when launching AutoCAD
When using the AREA command on a pline, the program freezes while interpreting area
Navigation in Infraworks similar to the Navigation Wheel in AutoCAD
Text does not show up in drawings, and the Style dialog box causes AutoCAD 2014 to crash
Error: “Error saving PDF file; PDF file is open or uneditable” when publishing from AutoCAD
Resolution display changes from top to bottom of display on high resolution monitor in AutocAD
SaC: Shortcut keys on my laptop keyboard doesn’t work but works fine when I connect the external key...
Transparency set to a solid hatch is lost when the file is reopened in AutoCAD
You got a new computer. How do you transfer Autodesk products to the new computer?
AutoCAD tells me to connect to the internet when activating.
Changing the plot layout wants to update pc3 file
During installation, a dialog box appears stating ‘AecCB has stopped working’
Fatal error after changing printer properties in AutoCAD
Hatch disappears in AutoCAD 2018
Error: A StartDocPrinter call was not issued when plotting to PDF in AutoCAD
Attributes cannot be removed from existing blocks in AutoCAD
AutoCAD: Fatal Error when the current Linetype is set to a specific custom linetype and a circle is ...
Move dimension does not work in AutoCAD when you enter a number value
Network shortcuts are unable to be used in Design Center in AutoCAD
PDF Import will not convert text to AutoCAD text
Vault Addin “Exception in vaac_addin.arx ARX Command”
Wrong presentation of viewbases of the model
AutoCAD Launcher is missing after installing
Where to download AutoCAD
Change the dimstyle for all new drawings in AutoCAD
Creating Area Room Tags linked to polylines
Error: “DWFx file was originally published as DWF” when trying to open DWFx in AutoCAD Markup Set Ma...
Extra lines cover DWG opened in DWG TrueView installed in a Citrix environmment
How to set default height of text on multileader
How to stop the model tab from being added to the publish sheet list in AutoCAD
Importing *fbx files from Mudbox2016 into AutoCAD 2018fails with empty model
License stuck in Trial mode
The PAN command gets stuck on in a drawing, and is unable to be ended without closing AutoCAD
Annotative attributes display very large in older files when opened in AutoCAD 2018
Plot Stamp Settings button generates warning dialog in AutoCAD
Single User License - Frequent Sign In (Every 30 Days), can users bypass this workflow?
The Security System(Softlock License Manager) is Not Functioning or is Improperly Installed
AutoCAD asks to insert a install disk when attempting to install the software
AutoCAD : Unable to retain sketch after doing an extrude
AutoCAD 2017: Dotum fonts plotted with extra space between text characters in PDF
AutoCAD 2018, Error 1317. An error occurred while attempting to create the directory
AutoCAD failed load VBA projects since the last Windows 10 update
AutoCAD pop up is docked in ribbon
AutoCAD: “You do not have permission to access Online Map Data”
AutoCAD: Nothing happens when clicking on the A360 shortcut in the file opening dialog window
AutoCAD® Mechanical: Missing geometries in some certain migrated dwg
Can I use my AutoCAD/AutoCAD LT 2017 for Mac license with AutoCAD/AutoCAD LT 2017.2?
FlexNet Licensing error:-59,696
Selecting item on Properties palette shows “No selection”
ARCH.SHX font displays blank characters in AutoCAD
AutoCAD: Fatal Error: Unhandled Access Violation Writing 0x0000 Exception at e18916edh when wokring ...
Creating a keyboard shortcut in AutoCAD LT
Freezing layers of a xref in the layout is slow after update to AutoCAD 2018 1.1
General installation workflow for Autodesk Product
How to delete an Electrical Project Database from an AutoCAD MEP drawing
How to insert objects in AutoCAD that look like stones
Layer property manager freezes randomly in AutoCAD
OFFSET command requires numeric distance, two points, or option keyword.
PDFSHXTEXT command does not work in AUTOCAD 2017
AutoCAD windows freezes when opening XREF window
How to change my email in AutoCAD 2018
Freezing xref layers turns off the whole xref in AutoCAD
Installation error: A newer version of this product is already installed (error code: 1603) or the p...
Revit - text elements of linked AutoCAD drawings print too thin
CustomAction UnzipZipFiles (error code: 1603)
February 2018
Plant 3D : Plot preview of a Non Plant drawing comes as blank
Poor graphics performance with AutoCAD for Windows
Troubleshooting the Mouse or Pointing Device used with AutoCAD
Add-A-Plotter Wizard is missing in AutoCAD
Drawing shows errors but unrecoverable
FATAL ERROR: Unhandled Delayload “D3DCOMPILER_47.dll” in AutoCAD
Geo-referencing after maintenance plan ended
How to close the top ribbons in AutoCAD
How to edit the block used for the vltrevblock command in AutoCAD
How to repair a corrupt AutoCAD installation on the Windows Operating System
Improving AutoCAD performance with older or low-end graphics cards
“Internal Failure” error while installing AutoCAD
AEC Collection - Included Software
AutoCAD : How to create a XML from AutoCAD drawing
DXF opens slowly in AutoCAD 2018 with Carlson Survey
How to migrate custom toolbars from old release to new release in AutoCAD
Launching AutoCAD shows missing shortcut to acad.exe
Orange block following cursor on screen in AutoCAD
Revit export to AutoCAD opens with wrong program
Troubleshooting poor AutoCAD performance after an Operating System update
Troubleshooting poor performance with specific drawings in AutoCAD
Unable to change color, lineweight, or linetype within the Layer Properties Manager or Layer States ...
Unable to install AutoCAD using the Install Now method
Z value changing by itself in AutoCAD
AutoCAD crashes when launching
AutoCAD crashes when trying to Save As or Batch plotting
AutoCAD keeps crashing when installed on Windows user profile with restrictions
AutoCAD locking up on Home screen after opening the drawing from Windows explorer
AutoCAD Text Window loses focus when moving a mouse cursor
AutoCAD: Annotation Scale Pop up off to one side of the screen
AutoCAD: How can line be plotted in color using CTB plot style
Automatic save in AutoCAD does not create an .sv$ file
Cursor and pick box are dissociated in AutoCAD
Dynamic Input not possible cause tooltip appereance setting getting wrong value when settings are im...
Error: EXPORTLAYOUT failed to generate a new drawing
Every Launch of AutoCAD gets the message ‘first runinitialization’
Hatch pattern does not display correctly or plot in AutoCAD
How to create your own AutoCAD tool palettes
How to install a new font in AutoCAD?
Mac user’s getting Javascript errors when downloading AutoCAD for Mac
Plotter name field reverts to ‘None’ after selecting plotting device
AutoCAD crashes shortly after signing in and sends a CER
Plot style can be selected, but does not effect the plot output in AutoCAD
Why AutoCAD single license will not cascade to Collection
Xref is Becoming Unloaded When Drawing is Opened
AutoCAD stuck checking license
How to export layer filters from a dwg to another in AutoCAD and Civil 3D
Right click menu in AutoCAD does not display when selecting objects
Section view on a 3D object fails to work in AutoCAD
Selecting a group in AutoCAD only selects individual objects
Tables insert at different sizes in AutoCAD depending on the Windows text scaling setting
The TEXTMASK express tool causes annotative text to disappear in AutoCAD
Using AutoCAD with RES ONE Workspace you get the error “Run Setup.exe to install Autodesk AutoCAD”
Vault: Can broken XREFS in DWG files be purged automatically
When batch publishing, linetypes will swap around unexpectedly in AutoCAD 2017
AutoCAD: The text in polyline linetype displays in opposite orientations throughout a continuous pol...
Can AutoCAD prevent users from opening files in Dropbox folder when someone is already working on th...
Can’t access tabs in AutoCAD with Cap Designer installed
Error opening PDF created using DWG to PDF
FATAL ERROR : Unhandled access violation writing 0x3f688758 Exception at 3f5f19fch in AutoCAD
AutoCAD fails installation when downloading the material libraries
AutoCAD command line error Message: “.arx - cannot find the procedure when executing a command”
Area of a hatch is not displayed in the hatch properties in AutoCAD
AutoCAD xref bind inserts odd characters into layer names
AutoCAD: Xrefs do not display in model space even tough they are well-loaded
Cannot open a dwg file in DWG True View: Problem loading dwgviewrres.dll resource file.
Error “You do not have permission to save to this location. Please contact administrator.” when savi...
Geometry with the same properties are displaying different line-type scales after being pasted into ...
How to export linetypes from a drawing in AutoCAD
How to turn off layer and comment information when plotting to pdf
Imported DWG file in Revit zoomed to extents moves the display out farther than it should
Invalid ARX error when launching AutoCAD
Vault: Revision block has a scale of 500 when inserted into an AutoCAD drawing
Would changing the server’s IP address affect our network licenses?
January 2018
SPDS Module 2018: Rip and section marks don’t automatically continue numbering
UI texts are gobbled and shown as rectangles in non-English AutoCAD based products on Windows 7
Software hanging after opening and loading the ribbon in AutoCAD
Solid could not be open “Error Code Number is 30015”
When loading a vlx routine the following error message appears: “no funktion definition: Vlax-ENAME-...
Zoom window is not zooming to the fully selected window, but only a small portion of it in AutoCAD
How to Report Piracy or License Compliance issue
Layer properties Setting button moved out of the dialog after LP installation
Selecting a Pline freezes AutoCAD
How to enlarge the layer list in the properties of AutoCAD
How to open CADRA (.cad) files in AutoCAD
Faster Copy and Paste access from the Right-Mouse Click Context menu
Dimension of lines is not working as expected in AutoCAD
DIMASSOC not associative with AEC Objects like walls in AutoCAD
Display issues when using VNC connection
No ‘Let’s Get Started’ Window or System Error Repair
Error: “License for this application has expired” when using APPLOAD to load a file in AutoCAD
How to zoom to layer in AutoCAD
Line weights are displaying correctly in paper space, but change when plotted from AutoCAD
Toolbars leave a trail while being dragged in AutoCAD on Windows 10 machines
Automatic renaming of layers with DWS file in AutoCAD
AutoCAD locks up about 2 seconds after opening it
AutoCAD: Images are not rendered in a perspective front view
AutoCAD 2018: Dimension string unexpectadly move position when stretched
AutoCAD does not display the Start tab with HydraCAD installed
MEASUREGEOM does not display results in model space in AutoCAD
Plotting from AutoCAD hangs showing “Plot job in progress” and never finishes
AutoCAD drawing will not open in the Autodesk Online Viewer
AutoCAD hangs at “Checking for License” - Flexnet error -12, 16
AutoCAD MEP 2017 Error - AecGuiInterop.dll & AecCore.crx
AutoCAD products fail to attach dwf files exported from Navisworks
AutoCAD: Clipping boundary is ignored when rendering clipped images.
Could not access network location or Invalid Congifuation path after Deployment Server is changed
Error message: “Run-time error ‘429’: ActiveX component cannot create object”
I am about to purchase AutoCAD for my computer and wondered if I should uninstall my student version...
Paper size is not retained in page setup when a dwg is moved from AutoCAD for Mac to AutoCAD for Win...
Selecting a drawing object requires two or more clicks in AutoCAD 2017
Show square meters for polylines in AutoCAD
You receive the following errors “login credentials are incorrect” or “an error 41”
Creating spline with arrow in AutoCAD
Annotative text shifts in AutoCAD when viewed at different scales
AutoCAD 2018 : Arcs converted to diagonal lines while opening the drawing
AutoCAD 2018 : How to find order in which layer list is exported to the IGES format
After reinstalling AutoCAD 2017 you received error “Problem loading acadres.dll resource file”
AutoCAD: Plotting OLE Images With Transparencies to PDF ignores transparency
A point cloud is printing with one section translucent and the other sections dense in AutoCAD, no m...
‘Always Load’ setting is not retained for AutoCAD add-ins
A new digitizer is not drawing to scale even after calibration in AutoCAD
AutoCAD 2017 crashes right after launch and shows Crash Error Report (CER) window
AutoCAD 2018 Core installation failure on CheckForRunningTasks
Can’t display coordination model and pdf in the same drawing in AutoCAD
Drawing objects disappear when zooming or panning in AutoCAD
Linetype Changes After Regen in AutoCAD and verticals
Scripting errors and licensing errors when loading AutoCAD 2018
Unknown command “VPEMOVE” in AutoCAD
Vault property mapping doesn’t work for user defined properties
When opening drawings that are a part of a sheet set, the drawing opens in AutoCAD but the sheet set...
AutoCAD 2018 stuck at Windows 10 upon opening
AutoCAD : How to convert PLT files to AutoCAD Drawing
AutoCAD 2017 and higher, Stuck at Trial mode - MAC OS
AutoCAD 2018 : How to open a 3D Canvas file in AutoCAD
AutoCAD crashes with a Fatal Error half way through publishing a job
AutoCAD: Layout from Template does not work, drawing border is missing
About Exporting Drawing Files to PDF
AutoCAD Installation Error 2908 & Error 1935(Ac32BitAppServer)
AutoCAD is stuck on loading because of spoolsv.exe process
AutoCAD: Cursor disappears
Cannot Activate AutoCAD when devices are restricted from manage site
Choosing Copy from Right-click menu options in command line input history crashes AutoCAD Map 3D 201...
Dimensions are showing decimal inch even though units are set to Architectural feet and inches in Au...
FLATSHOT command in AutoCAD gives message “there are no solids or surfaces that can be projected”
Linetype display changes when entering Block Editor in AutoCAD
Navisworks model not displayed in PDF when printing with visual style is set to Realistic or Gooch i...
Matt DiMichele
diana.yr
October 2018
AutoCAD hangs when trying to enter a text in a drawing of AutoCAD
Layers display different in model space vs paper space in AutoCAD
PDF printed from Revit cannot be selected in AutoCAD
Printing is very slow in AutoCAD for small drawings
Recovering drawing files which fail to open in AutoCAD
Graphics card shows as certified but not recommended for AutoCAD products
Attaching point cloud from ReCAP into Civil 3D showing zero Z-coordinates
Custom control code for font doesn’t work with multiline text in AutoCAD
How to create nested plots in AutoCAD
Modifying Multileader style in AutoCAD
Optimizing the AutoCAD drawing file: Purge, Audit & Recover
Error: “LI_NWC_SEVERITY_ERROR” when launching AutoCAD
DIMORDINATE command shows wrong coordinates when custom User Coordinate System (UCS) is used in Auto...
AutoCAD units are reading in decimal
BLOCKs cannot be added to a custom tool palette stored on a file server in AutoCAD
Deployment not installing service packs and updates silently
Error: “You seem to be offline, please check your network connection” while trying to login to AutoC...
Generic icons show for AutoCAD DWG files in Windows Explorer
Unable to choose the Dynamic Grip Menu options in AutoCAD
AutoCAD files are not synchronized in OneDrive
Freezing a layer in AutoCAD causes objects or blocks on other layers to disappear
How to convert DWF files to DWG format in AutoCAD
How to create a buffer zone around solids by offsetting their edges
Running Scripts using ScriptPro v 2.0 in AutoCAD 2018
Select linework does not zoom along with other linework in AutoCAD
Saving from AutoCAD through Desktop Connector to BIM 360 Document Management
Switching between computers with a KVM switch crashes AutoCAD
The color of raster file change with rotating in AutoCAD
During Autodesk software deployment creation, will the serial number change from time to time?
Some of the AutoCAD commands stop responding
Custom line style changes while working or copying them into a new drawing in AutoCAD
How to get paragraph symbol visible in MText in AutoCAD
When plotting PLT files with AutoCAD, some text elements are missing
Error: “Error! - no elements available” when opening an AutoCAD PLT file in a third-party software
How to combine multiple drawings in AutoCAD in one main drawing
How to show centerlines on a curved solid in AutoCAD
Render engine used in AutoCAD 2019
Raster image in AutoCAD does not appear in preview or when plotted to PDF
Rendered arcs are shown as straight lines in AutoCAD
Using objects connected to a color from standard color books crashes in AutoCAD
Can users bring in large number of AutoCAD objects into Inventor
Drawing a line via OSNAP and tabulator key creates a wrong line length in AutoCAD
Hatch missing in plot output when batch plotting to pdf from AutoCAD using particular PC3 files
Compiling a large LIST in VLIDE gives a warning when the list contains more than 255 elements
Menus show in a different language when Specialized toolsets are installed
Update 2019.1.2 available for AutoCAD and AutoCAD LT
Some colors are printed with a different tonality in AutoCAD
How to prevent the Data collection and use window from appearing when opening AutoCAD
When zooming in and out within a viewport on a layout, Civil 3D freezes
How to automatically update data links in AutoCAD
How to manage the draw order when creating hatches in AutoCAD
How to place a Title Block on a Layout in AutoCAD
Text is visible in PDF although the visual style is set to hidden in AutoCAD
Command line moves or does not hold its position in AutoCAD
Text is not keeping central position in a table in dynamic block in AutoCAD
Synchronizing from Autocad 2019 to the Cloud
Plot Preview shows black and white in AutoCAD
Which Autodesk Product converts step file to Navisworks (NWC) format
DWG files appear empty after opening/ importing them in Inventor
When trying to quantify an AREA of an object a “?” appears and no value is indicated in AutoCAD
Objects are scaled incorrectly when attaching a drawing as Xref
Printing dwg to pdf in AutoCAD results in a very large file size when using
September 2018
Crash when plotting to PDF in AutoCAD
Exported MEP Fabrication round ductwork from Revit to DWG shows single line in AutoCAD Wireframe mod...
FLEXnet License Finder always prompts for license server when launching Autodesk software
Union command doesn’t combine different types of 3D objects in AutoCAD
XY coordinates is different from model space to paper space in AutoCAD
Error: “Network License Not Available” Error 0.0.0
NWC file with large coordinates is distorted when opened in Civil 3D
Error: “Failed to load C:\users\\appdata\local\temp_ai15e6.tmp\setup\contentpackui.dll (126)!” when ...
How to track changes made to a drawing in AutoCAD
Grip menu disappears in AutoCAD on 4K monitor when using individual display scaling at 150%
Losing AutoCAD DWG file associativity in Windows
Missing drawing data in Vault Viewer
Autosave does not Work during REFEDIT or BEDIT in AutoCAD
Faulting module nvoglv64.dll when launching AutoCAD
Original font types changing in AutoCAD
How to create a custom linetype in AutoCAD and verticals
How to keep full address when copying or pasting a raster between DWGs in AutoCAD?
How to reduce image size while keeping georeferences in place in AutoCAD
Multiline Text is shown in vertical rather than horizontal in AutoCAD
Unable to publish black and white PDF files in AutoCAD
Error: License error. Your license is invalid. Please contact your local authorised AutoCAD dealer.
How to convert a Microstation block library (CEL) file into a drawing in AutoCAD
Package Feature Code 87195ACDIST_T_F appears in debug file for AutoCAD
Text extends beyond desired formatting in AutoCAD
AutoCAD hangs at checking license stage and doesn’t give you an option to enter a serial number
Error: “Hatch Object Limit Exceeded” in AutoCAD
Moving or otherwise manipulating objects in AutoCAD hangs the program
Repeating pause or hang about once a minute in AutoCAD
Text shows differing fonts within the same line or word in AutoCAD
When I migrate network license to new server, should I return the old license file to Autodesk?
PDFs created in AutoCAD 2016 and newer are darker than with previous versions
August 2018
Error: “The path of the added item is too long Please limit this path to 82 characters” when trying ...
Error: “This drawing will display the message, "PRODUCED BY AN AUTODESK EDUCATIONAL PRODUCT.” Do you...
Fatal Error : Unhandled access violation reading 0x318b8070 Exception at 72efc145h
Grip menu items disappear on mouse over in AutoCAD
HIDE command after save causes items to vanish in AutoCAD 2016 or later
How to import survey data from excel into AutoCAD
MText does not have style property in AutoCAD
Object snaps do not work in AutoCAD
AutoCAD can not print the size of 5500mm
Unavailable parking Layout in AutoCAD Civil 3D
Hatch disappears when clicking to edit it in AutoCAD 2019
Stretch grip of AutoCAD dynamic block dose not stay at the corner
Unable to install Autodesk Vehicle Tracking
Download SPDS module for AutoCAD
Fatal Error: “Unhandled Access Violation Reading 0x0000 Exception at CF886F40h” in AutoCAD
How to create a nesting DXF with a specified sheet size in AutoCAD
Color Books don’t load in AutoCAD after adding custom Color Book (ACB) files to support folder
Conditional dimension style in AutoCAD
Delay when exiting commands in AutoCAD
DWG exported as ACIS solids from Revit shows additional lines in AutoCAD
Error: “INTERNAL ERROR: dbobji.cpp@8597:eNotOpenForWrite” when editing a block in AutoCAD
Mirrored mtext inside a block plots upside down to PDF from AutoCAD 2016 and 2017
QSAVE does not default to DXF file type when working on DXF files in AutoCAD
Revcloud with calligraphy style is not displayed correctly when the drawing is opened in AutoCAD
TIF image rotated at non-orthogonal angle displays and plots faded in AutoCAD
Cannot upload files in cloud rendering web portal
Command Line changes when opening any AutoCAD based program
PDF print generates random lines over hatch objects in AutoCAD
Can drawing template settings be exported from Revit to AutoCAD
Plotting to High Quality PDF results in missing drawing content
Update 2019.1 available for AutoCAD and AutoCAD LT
Hatches will not printed from PDF saved in AutoCAD via batchplot
Can you input the bearing and distance when drawing in AutoCAD Mobile?
Xreferenced image caused material assigned to Surface (Planar) not to print
AutoCAD Raster Design shipment with an AutoCAD subscription
Autodesk network license server doesn’t start as a Windows service
Cannot plot over 129 inches from HP Designjet T795 from AutoCAD
Drawing which has transparent and gradient hatching very slow to pan in AutoCAD
Error: “A new version is already installed” when installing AutoCAD OEM 2019 German
July 2018
Open from web feature cannot be fully disabled after update 0.1 was installed for AutoCAD 2019
AutoCAD LT 2019 crashed at initializing stage
Cannot snap to lines underneath dense hatch in AutoCAD drawing
Cropping an image in AutoCAD
How to change the language for AutoCAD 2019
Plotting a graidient fill from AutoCAD shows a gap at the edge
Settings of layers of external references (XREF) won’t be used in template drawings in AutoCAD produ...
Copy and paste x,y,z points into the SPLINE command from Excel on AutoCAD for MAC does not work
AutoCAD 2019: Cloud rendering doesn’t work
AutoCAD freezes on “checking license” with Wacom ISD Service installed
AutoCAD starts as a trial
Error: ‘Invalid or unsupported image file’ when dragging image files into AutoCAD
Error: “Internal: invalid input data for decode” when plotting or exporting from AutoCAD
Error: “You cannot install this product on the current operating system.” when installing AutoCAD
Exported DWG’s from Fusion 360 have a red box around them when opened in AutoCAD
Joining polylines in AutoCAD loses a vertex
Moldflow 2019 Installation disappears after initializing on computers with 1TB Memory
Object color changes while exporting to DXF from AutoCAD 2018
Project setup is freezing when editing Tag format in Plant 3D
Updates for Autodesk software in a deployment do not install silently when using SCCM
AutoCAD 2017 crashes every few minutes when drawing a 3DPolyline
AutoCAD LT 2019 hangs on checking license
AutoCAD LT for Mac does not work with projects on network drive
Convert DGN to DWG shows discrepancy in color numbers
Error: “The system does not support the command requested” when plotting from AutoCAD
Error: “Unable to save drawing” and random crashes in AutoCAD with antivirus
Inserting a block gives different draw order in AutoCAD 2019
Viewport always appears behind paper space objects in AutoCAD
2D views exported from Revit are always at the elevation 0 in AutoCAD
Cannot import pay item file for Swiss Country Kit 2018
Geographic location causes inserted online map to get rotated, if there’s an image with worldfile in...
How to remove CTEXT annotations in Isometric views in Fabrication CADmep
How to use updated specs for other AutoCAD Plant 3D / Vault projects?
Diana Rouge
Social Media Specialist
