Question: Where can I find a list of the latest Autodesk Knowledge Network support solutions that were created and/or updated regarding AutoCAD?
Solved by matthew.d. Go to Solution.
December 2017
November 2017
October 2017
September 2017
August 2017
July 2017
June 2017
May 2017
April 2017
March 2017
Extra file calls are made when opening DWGs in AutoAD 2015 and older
Problems when plotting MyriadRegular font from AutoCAD to PDF
AutoCAD: Table changes color and thickness of cell’s when move or copy
Moving the cursor over icons makes Windows on Parallels open multiple windows
Excel workbooks open as hidden files that stay open in background in AutoCAD
AutoCAD: Lag in performance when attaching a PDF
0 days left on AutoCAD and AutoCAD LT 2018
When importing an AutoCAD DWG (3D Objects) into InfraWorks the geometry is corrupted
System requirements for AutoCAD 2018
Where is Autodesk Material library located on hard drive
Advance Steel: How to open detail drawings in pure AutoCAD
How to divide hatch of complex area in AutoCAD
AutoCAD is slow to launch and randomly shuts down when opening files, or in the middle of work
AutoCAD is using some command other than what is selected
3D objects plot with jagged lines in AutoCAD
Cannot publish multiple sets of drawings from AutoCAD
How to convert a CV splines into a Fit one
How to flatten a drawing in AutoCAD
DISTANCE command returns an incorrect measurement in AutoCAD
PDF Import icon not showing in ribbon in AutoCAD 2017
Text background is shifted if plot to DwgtoPDF
Unable to locate the English version for Autodesk AutoCAD 2016 DWG to PDF Custom Properties Hotfix
How to set a value of a systemvariable when starting AutoCAD
How do I know what LISP programs are loaded AutoCAD
Pan and Zoom no longer work using mouse center scroll button in AutoCAD
AutoCAD hatching does not work properly
Automatically export multiple layouts to separate drawings
AutoCAD: Copy and paste dynamic blocks between drawings does not retain changes in blocks
AutoCAD freezes and then crahses when selecting “User hatch pattern” from the ribbon
Block disappears when exploded or burst in AutoCAD
DISTANCE command does not show results at the mouse cursor in AutoCAD
Drawing window flickers black in AutoCAD
Error: “Point or option keyword required” when drawing in AutoCAD
Editing a block in AutoCAD results in AutoCAD freezing for a few minutes
How to import a layout with viewports from one AutoCAD file to another
How to change Brightness and Contrast for Raster
AutoCAD: Plotting to company’s PDF does not plot properly
AutoCAD hangs after showing “Loading AeciRibbonUiApi…” on the command line
AutoCAD FATAL ERROR: Unhandled Access Violation Reading 0xfffffffff Exception at d2fea7c0h
Can’t publish from AutoCAD using a sheet set override
Cannot change the color of elevation marks in AutoCAD
AutoCAD PDF Import does not scale as expected
How to change text height globally in AutoCAD.
How to change the amount of time the temporary prompts display above the single floating command lin...
How to modify the scale of specific linetypes in AutoCAD
Ellipses plot incorrectly in Legacy Hidden shade plot in AutoCAD
Grips are not working or missing on hatches in AutoCAD
AutoCAD doesn´t recognize digital signatures installed in Windows
How to create a custom part in AutoCAD Plant 3D using an AutoCAD block
Issues when converting to JT file with FactoryCAD within AutoCAD 2016
AutoCAD asks for Serial Number on launch even though just Sign In is required
BIM 360 Glue: How to upload models from AutoCAD
Certain linetypes from .lin file not importing in AutoCAD
Drawing is turning white all of a sudden with no apparent reason or consistency
Text randomly shifts in AutoCAD
February 2017
Where to find, install Updates or Service Packs for AutoCAD 2017 or newer
Huge delays with standard commands in AutoCAD when Factory Addin is loaded
How to use AutoCAD details in Revit
Hardware acceleration is unavailable after resetting AutoCAD to defaults
Grips stop appearing on solids in AutoCAD
Error: “Printer name is invalid” in AutoCAD
SAT model imported into AutoCAD has the wrong size
AutoCAD: Stuck in Model space through paper and can’t get out
AutoCAD will no longer launch
Orphaned linetypes cannot be removed in AutoCAD 2013
Can AutoCAD Architecture install AutoCAD patches
Product installed from USB not working normal
Cannot download AutoCAD 2017.1.1 Update 32-bit from the Product Updates tab
Error: “Modeling Operation Error: Loft surface self-intersects” in AutoCAD
How to batch remove old plotter settings from a dwg
Annotation texts are moved when a drawing is saved as AutoCAD DWG in Inventor
How to snap to a tangent on the fly
Some paper sizes are missing in the selected plotter
Hilti plug-in for AutoCAD will not run
In AutoCAD the angle between items of a polar array is rounded to the nearest whole number
Unable to dock the ribbon to the top of AutoCAD
AutoCAD Freezes when switching layouts
File takes a long time to open in AutoCAD after changing server name
In AutoCAD based product Using Publish Selected Layouts does not plot all layouts
XLine will not work properly when snapping to an endpoint in AutoCAD
Application Autodesk AutoCAD always launching new by opening a file dwg
AutoCAD won’t open older files
AutoCAD will not created published PDF
How to display the AutoCAD drawing setup wizard
AutoCAD locks up when switching between model viewports
Points deleted in ReCap reappear when the project is loaded into AutoCAD
Unable to add a tangent constraint between 2 objects
How to create a slope hatch in plain AutoCAD?
Where are the automatic save-files saved?
Text plots out larger than it appears in AutoCAD
PDF file size increases in AutoCAD after installing the 2017.1.1 update
Ellipses on layers frozen in viewport still plot in AutoCAD
AutoCAD: Application OPTIONS reset after restarting AutoCAD
Double-clicking a DWG file opens a blank drawing in AutoCAD
Cannot enable hardware acceleration with Nvidia GeForce graphics card
Editing standard paper size margins in the plotter configuration editor
External references are not keeping their updated paths
AutoCAD 2017: PDFSHXTXT command does not work
When rotating the image disappears in AutoCAD
BVSTATE dialog box does not open in AutoCAD block editor
XREF palette does not display in AutoCAD
Autodesk Inventor is slow when importing AutoCAD DWG
How to insert a CTB or STB file from another end-user in your DWG file
Unable to add custom paper size in AutoCAD
AutoCAD crashes or freezes when running the HATCH command
How to use font Wingdings for linetypes?
AutoCAD 2017: Fatal Error: Unhandled Access Violation Writing 0x0000 Exception at e18916edh
Commands freeze on AutoCAD 2000 formatted drawings
January 2017
Bad quality render when objects are far away from drawing origin in AutoCAD
Copy to clipboard (CTRL+C) does not work in AutoCAD
Edge of viewports plots despite being on a non-plot layer
Excel data link will not insert or update reliably in AutoCAD
Multiple viewports do not display for on a layout in AutoCAD
Registry key that is set after AutoCAD 2016 Hotfix 4 installation
Spline in DXF file becomes broken when it’s opened in AutoCAD
Unable to attach a DWG file as an external reference (xref) in AutoCAD
Unable to change layer name in AutoCAD
Understanding purging of an AutoCAD file after copy paste has been done
Using WBlock to write out a portion of your file to a new file in AutoCAD
Viewbase command does not work when a drawing was saved in a newer version of AutoCAD
XREF files cannot be edited in AutoCAD
