AutoCAD Forum
2016: Table Styles not reflected on created tables
3 REPLIES 3
331 Views, 3 Replies
See attached screenshot: both tables are set to the same table style
So why does the word "point" fit on one line on the top table but can't manage it on the bottom table when both columns are the same width?
Looks like I'm creating a text box over it that works properly for now, just another waste of time in my day using Autocad.
3 REPLIES 3
Vinayv4v
From the image you have attached its clear that both tables have different row heights. 2nd table has same width but the row height is different than the first. Select each table individually and check in properties their dimensions. You can see those are different.
If you select the window method then only either one can be given a value and other value will be assumed according to the window you draw.
To be of the same column width and row height you need to create table using the insertion method.
Why you didn't use the COPY command to create the 2nd table  with same dimensions of the first ?
Cheers,
Vinay Vijayakumaran
Alfred.NESWADBA
can you please upload the drawing? In the screenshot we can't select objects and look into their settings.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Vinayv4v
From the image you have attached its clear that both tables have different row heights. 2nd table has same width but the row height is different than the first. Click each tables separately and check in properties the dimensions for each. Maybe you have streched the 2nd table a little.
Cheers,
Vinay Vijayakumaran
Forma Design Contest
AutoCAD Beta
