AutoCAD Forum
2014 open dialog window
3 REPLIES 3
495 Views, 3 Replies
A small issue but very annoying. When I open a new drawing, the open dialog window stays the same size which is usually too small. I have to resize it everytime I open a drawing. Anyone else have this problem?
3 REPLIES 3
nrz13
Are you using more than one monitor and, if so, is the dialog opening on a monitor other than the primary monitor?
If so, this is a known limitation of AutoCAD.  AutoCAD will only remember the window size and position if the dialog is on the primary monitor.
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 32GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
in reply to: nrz13
Ah... yes I see now. thanks for the info.
nrz13
You're welcome.  I agree that it's quite annoying.  By the way, this holds true for all dialog boxes, not just the Open dialog.
Forma Design Contest
