AutoCAD Forum
2014 LT - Nvidea Graphics
2 REPLIES 2
qfanatiq
1850 Views, 2 Replies
See report below
Got the perfoamnce report after installing AutoCAD 2014. Since then simple zooming makes the bottom right hand icons flash erratically and the end result taking some time, stopping and starting on the way (of the wheel induced zoom).
I went to this site to get the driver (http://www.nvidia.com/object/AutoCAD_PD_workstation.html), hoping despite running 2014 they wouldl work. However, I get a message saying no drivers found to updtae.
Can anyone shed any light or help me out?
Cheers.....Q
Performance Tuner Results Log
Version: 19.1.0.02
Date of Last Tune:
Machine Configuration
Processor Speed : 3.2 GHz
RAM : 4057 MB
3D Device
Name : NVIDIA GeForce GT 620
Manufacturer : NVIDIA
Chip set : GeForce GT 620
Memory : 2750 MB
Driver : 9.18.0013.1106
Your machine contains a 3D Device that is not certified.
As more graphics cards and 3D display drivers are tested, they are added to a list on the Autodesk website.
You can check for updates and download the latest certification list at any time. Run the 3DCONFIG command and click the Check for Updates button.
Current application driver: acaddm11.hdi
Current Effect Status:
Enhanced 3D Performance: Available and on
Smooth display: Not available
Gooch shader: Software emulation in use
Per-pixel lighting: Not available
Full-shadow display: Not available
Texture compression: Not available
Advanced material effects: Not available
Available application drivers and effect support:
Software driver
Effect support:
Enhanced 3D Performance: Not applicable
Smooth display: Not applicable
Gooch shader: Software emulation only
Per-pixel lighting: Not applicable
Full-shadow display: Not applicable
Texture compression: Not applicable
Advanced material effects: Not applicable
Autodesk driver: Not Certified
Effect support:
2 REPLIES 2
pendean
in reply to: qfanatiq
Read towards to end of this thread of solutions posted in the correct LT forum where you are not posting for a common fix 🙂
http://forums.autodesk.com/t5/AutoCAD-LT/AutoCAD-LT-2014-Flickering-Issue/td-p/3875348
qfanatiq
in reply to: pendean
Thanks Dean for both sets of information.
Q
Forma Design Contest
