180*** series errors occurring when trying to export drawing to .stl file
opesey
opesey
Appreciate the read in advance. I am using AutoCAD 2025 and designing a bash bar for an automobile. The part has many extruded cylinders that are sliced to create clean "bends" and edges. I have made 3 iterations to the print and during the addition of the last few edits, I am not getting an error during the export process. These range from different error codes, but all have the 180 (18012,15,33 and a few more) designation.
I have tried to revert back to old files and print them, they are fine. Even taking away the new parts on this drawing, it still throws the same error code. I have redrawn the part, accounting for unsolid surfaces and cleaned it up, still it is showing the same errors.
Any help would be appreciated. Thanks in advance.
pendean
Community Legend
Community Legend
is this a problem you have with all of your files and 3DSolids, or just this one?
That's a rare one from hat I can find https://forums.autodesk.com/t5/autocad-forum/i-cant-convert-dwg-to-stl/td-p/11892797
opesey
Just an issue with this specific part. It only cropped up about 3/4 of the way through designing it and no amount of re working it has been beneficial yet.
pendean
Community Legend
Community Legend
Can you share your DWG file here? Point to the specific part inside that please.
opesey
Sending over the original part.
Valentin_CAD
@opesey ,
Must clean up duplicating and overlapping objects.
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
opesey
got it working, thank you all. your suggestions worked smoothly.
