10 property limit in AutoCAD Propulate
peterjwinberg
Message 1 of 8
peterjwinberg
Is there any way around the limitation of copying only 10 custom properties?
@peterjwinberg,
john.vellek has edited your subject line for clarity: PROPULATE
Replies (7)
Message 2 of 8
john.vellek
Hi @peterjwinberg,
I am not aware of any way to add additional numbers of custom properties inside of Propulate.
You might need to hunt down another utility.
John Vellek
Message 3 of 8
peterjwinberg
A user can create as many custom properties as they want without using another utility, and a template can be saved from that, but only 10 custom properties can be copied from a template using PROPULATE. The limit seems odd...
Message 4 of 8
TerryDotson
In the earliest implementations of the DWGPROPS dialog the custom properties were limited to 10 as well.  When PROPULATE was created it was following the established standard at the time.
If you were to consider third party software, email me at dotson [at] dotsoft [dot] com, I'm sure we can produce what you need if we don't have it already.
Message 5 of 8
peterjwinberg
Hey, thanks so much for the info 🙂
I will reach out if the need arises.
Message 6 of 8
john.vellek
HI @peterjwinberg,
I am coming back to your thread to see if the issue or question you posed has been resolved.  If so, please mark the post or posts as Solution(s) to help others find the answer quickly. If your issue persists, please give me a bit more detail on this issue so we can continue to work towards getting this solved.
John Vellek
Message 7 of 8
peterjwinberg
is the need for a third party utility considered a solution? 🙂
Message 8 of 8
john.vellek
Hi @peterjwinberg,
Of course it is. The feature is working as designed but if you want additional functionality, then a 3rd party utility is one solution.
You are also welcome to contact the product team directly. If you have additional comments specific to the software or its functionality for future consideration, please use the Product Feedback page. How to provide feedback on Autodesk products goes into more detail.
Another great option is to participate in the AutoCAD Customer Council. This is an opportunity for our customers to partner with the AutoCAD development team to improve future releases of AutoCAD by giving continuous feedback on ideas, designs, and early builds.
In order to get involved email autocad.beta@autodesk.com or autocad.lt.council@autodesk.com
John Vellek
