Anytime I try to "Print" > "Print Preview" the Preview Job Progress status bar starts and then freezes. Then I get the frozen color wheel and then the Mac, " Your system has run out of application memory" error message. And then I have to force close the program and restart it. Then the same thing happens when I again attempt to generate print preview. While this feels like a Mac problem rather than a CAD problem, I only experience difficulty where it pertains to CAD. Also, I received an email from autodesk: "On March 15, 2023, Autodesk Access will replace Autodesk Desktop Application?" When I download it, I am unable to open it.
I appreciate any suggestions...
Solved by maxim_k. Go to Solution.
Thanks for your reply. I'm using AutoCAD LT 2019 for Mac app.
on a 2019 iMac OS Ventura 13.2.1 8GB memory.
Hi @GuillaumeGentet ,
AutoCAD LT 2019 for Mac is not compatible with macOS Ventura and not supported on this new macOS version.
I think that explains the problem with saving to PDF.
You need to upgrade your AutoCAD LT at least to 2021 version or downgrade macOS.
