AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Older drawings, Cant view anything unless highlighted
11 REPLIES 11
Message 1 of 12
fredTJRMQ
442 Views, 11 Replies
I am trying to work on some older drawings in ACAD LT, but in both model mode and layout mode, I cannot see any of the drawings outside of some random lines here and there.
I have tried to torubleshoot it.  I'm sure it's a simple settings thing, but I cannot figure it out.
Please advise.  Thank you!
Tags (1)
11 REPLIES 11
Message 2 of 12
h_s_walker
in reply to: fredTJRMQ
Post one of these problem drawings so we can have a look at it ourselves.
We cannot advise with just a description.
Howard Walker
Left Handed and Proud
Message 3 of 12
fredTJRMQ
Here ya go.
Message 4 of 12
pendean
Greetings @fredTJRMQ
I see this in your posted file in LT2023.1.2
is there something else hidden you cannot see?
Message 5 of 12
fredTJRMQ
in reply to: pendean
this is what mine looks like.
that why i feel like it's a settings thing that i can't figure out.
Message 6 of 12
fredTJRMQ
Message 7 of 12
pendean
@fredTJRMQ This is not the MAC forum sadly, so that's possibly fixable: you are missing a required update to your LT2023 version but you cannot get it if it is "unregistered".
What is your MacOS version? And which MAC device is this?
I'll move you over to that forum, perhaps someone with your setup can shed more light on the matter.
Message 8 of 12
fredTJRMQ
I'm running Catalina 10.15.3
The device is a Macbook Pro
My version of AutoCAD LT is freshly downloaded.  I'm actually running a 30-day trial of it to see how I like it.  Not sure why it wouldn't be the latest version.
Message 9 of 12
pendean
@fredTJRMQ Autodesk only makes the initial release available to trial: updates and fixes require a paid subscription to get and install. "latest" means nothing here sadly.
Message 10 of 12
fredTJRMQ
thank you
Message 11 of 12
maxim_k
Hi @fredTJRMQ ,
What settings do you have for Graphics engine in Application settings?
If it is "Metal", then try to change it to "Open GL Core Profile", restart AutoCAD and try to open your drawing.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 12 of 12
fredTJRMQ
in reply to: maxim_k
That worked!!!  Thank you!
I took the advice of the person above you in the forum chat and ended up buying AutoCAD LT.  Actually spent a couple hours getting it to run because I had to delete the Trial version which involved deleting a bunch of source code in terminal.  Finally got it running and the issue was still there.  Came on here to post that the issue wasn't resolved.
Did what you suggested and voilà!
Thank you!
