Why am i seeing this? - see screen shot
I recently re-installed the MacOS on this computer and restored all documents and apps fro backup
Now I can't use Autocad
Can't i have simple answer for small scale users instead of a lecture
thanks
maxim_k
What AutoCAD version and macOS do you have on your Mac? I'm asking because you need to reinstall AutoCAD and the exact steps depends on AutoCAD and macOS versions.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
maxim_k
In general, you need to perform these steps:
- perform clean uninstall of AutoCAD:
https://knowledge.autodesk.com/support/autocad-for-mac/learn-explore/caas/sfdcarticles/sfdcarticles/...
- verify that AutoCAD version you have is supported on macOS you have on your Mac:
- use appropriate installer to install AutoCAD again, then install all updates (if they are not included with AutoCAD installer)
If you provide your AutoCAD and macOS version, I will able to give you more accurate instructions.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Dear Maxim
Thanks for the mail
I believe I have both Autocad LT 2019 and LT 2020 for Mac
My MacBook is on Catalina 10.15.1
maxim_k
For AC LT 2019:
- perform clean uninstall (see link above)
- install it again using original installer, which you can find in your Autodesk account:
https://manage.autodesk.com/cep/#products-services
- install AutoCAD LT for Mac 2019.1 Update:
https://knowledge.autodesk.com/support/autocad-lt-for-mac/downloads/caas/downloads/content/autocad-l...
For AC LT 2020:
- install AutoCAD LT for Mac 2020.1.1 Hotfix which you can get in your Autodesk account, or at least AutoCAD LT for Mac 2020.1 Update:
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
pendean
Community Legend
Community Legend
It is not enough to just install 2029 and 2020 versions, you must find and install the latest updates yourself for both programs to be Catalina capable too.
Search for and get those updates from your autodesk login account page.
