AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Using Associative Array for Mac
1 REPLY 1
410 Views, 1 Reply
Is it possible to turn off and no associative array for Mac? Windows version has a button on the screen. Having trouble deleting one item in an array
Tags (1)
1 REPLY 1
maxim_k
Welcome to Autodesk Forums!
Hi @Anonymous ,
If you need to delete single item in associative array, you can select it with Ctrl key pressed, then use Delete kye to delete it.
If you want non associative array to be created by default, set system variable ARRAYASSOCIATIVITY=0 :
https://help.autodesk.com/view/ACDMAC/2021/ENU/?guid=GUID-1BF5C611-A64C-4394-A932-AFEC1A5F9385
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Technology Administrators
