Flatten drawing the got z values by mistake?
Message 1 of 9
I'm working on a project currently where we've drawn the site plan (intended to be 2D) and for some reason a number of the lines were not constrained to a Z value of 0. Any ideas on how to flatten it now? I'd rather not redraw the whole thing. I've tried running the .lsp file for flattening, all the x and y values for the objects change as well and the site plan gets scattered all over model space.
Any help would be great.
Thanks!
Replies (8)
Message 2 of 9
maxim_k
Welcome to Autodesk Forums!
Hi Lisa,
At first you need to set UCS to World:
http://help.autodesk.com/view/ACDMAC/2016/ENU/index.html?guid=GUID-0BE49DA1-B323-4758-B49B-4C497D194...
Than use PLAN command to set viewpoint perpendicular to the current UCS:
http://help.autodesk.com/view/ACDMAC/2016/ENU/index.html?guid=GUID-3779DF52-AA24-47D2-B72C-018D4A901...
Now try this trick:
http://ltunlimited.typepad.com/my_weblog/2010/07/mimic-express-tool-flatten.html
Or you can select all objects in your drawing, than use Properties palette to show properties for each type of objects (just open drop-down list at the top of the Properties palette, where you see "All(xxxx)" and select each type of objects one by one) and set their Z value to zero.
For example for LINE objects you need to set Start and End Z to zero, for TEXT set insertion point Z=0, for POLYLINES set elevation to zero, etc.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 9
Emmsleys
Did any of the posts in the thread help with you issue?
Please select Accept as Solution for post in this thread resolves your issue, or reply with additional information if the problem persists.
Thanks.
Sarah Emmsley
Technical Support Specialist
Message 4 of 9
Emmsleys
To add this user found a unique workaround.
Using a macro take a look at it here: Recreating the FLATTEN Command in AutoCAD for Mac
Sarah Emmsley
Message 5 of 9
francesco.arneodo
Community Visitor
Community Visitor
Hello, I have the same problem with AutoCAD 2022. I tried the FLATTEN command but the app freezes and I have to force quit it. Any suggestions? Thanks!
Message 6 of 9
maxim_k
Hi @francesco.arneodo ,
Usually FLATTEN command works fine with drawings.
Does AutoCAD freezes with FLATTEN command only in particular drawing?
If yes, can you share it here? Or you can send it to my email - [email protected] - I can look at it.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 9
francesco.arneodo
Community Visitor
Community Visitor
Thanks! Will send a sample shortly.
Francesco
Message 8 of 9
maxim_k
Francesco,
I was able to flatten your drawing with FLATTEN command without freezing AutoCAD.
I noticed that view direction was not perpendicular to XY drawing plane, so at first I used PLAN command to set view to XY plan. Then I used FLATTEN command with "don't remove hidden lines" option and after a few seconds I got flattened drawing.
I sent it to you by mail.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 9 of 9
francesco.arneodo
Community Visitor
Community Visitor
Thank you!
