unknown command
unknown command
unknown command
hi, well i was designing something to school and i had to do a tangent with circles and lines, but when i typed TAN a message appeared and said unknown comman TAN F1 to help and i pressed F1 but i couldn´t resolve the problem. Can somebody help me? Thank´s
maxim_k
Welcome to Autodesk Forums!
If you need to use tangent object snap, you need to type TAN inside some drawing or editing command when AutoCAD asks for point input.
TAN is not a command, but a command modifier - you can not use it outside a real command, such as LINE, ARC, MOVE, COPY, etc.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Thanks for your help, i was doing it so bad. But i took your advice and it has helped me a lot. Thank's
