AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Units not saved correctly
2 REPLIES 2
n01430349
601 Views, 2 Replies
Hi everyone!
I'm a new autocad user in an introduction to autocad course at college, and I have a question about changing units. I was taught that to change the drawing units to use the Units (Command), and change the drop down menu option to millimetres (what we are expected to use). However, after I did this for an assignment and submitted it, I was docked marks because my prof (a windows user) opened my .dwg file and my drawing was in inches.
Any ideas what went wrong here, or perhaps is there somewhere else I need to change the units as well?
Thanks!
Tags (1)
Labels (1)
2 REPLIES 2
maxim_k
in reply to: n01430349
Welcome to Autodesk Forums!
Hi @n01430349
You need also verify that:
- the "Type of units" in "Units" window is "Decimal"
- System variable MEASUREMENT = 1
- System variable INSUNITS = 4
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
n01430349
in reply to: maxim_k
Awesome, thanks so much, Maxim!
I also found that if I set up my drawing using -DWGUNITS (setting it to <3>, then accepting the rest of the settings) BEFORE drawing anything, this also ensures the correct units across the board.
Cheers,
Nic
