Uninstall of Autodesk does not work
moritz_kirschbaumAYZZ7
Observer Observer
Observer
Observer
Hello community,
I don't need AutoCAD for mac anymore and so i tried de uninstall. I did all steps which are published here:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Clean-uninstall-of...
but i does not work properly.
After restart, there appears still an "Autodesk" folder and an process named AdskAccessServiceHost and the Licensing manager. Everytime I quit the process, it starts again a few minutes later and I get the message "AdskUtil ended unexpectedly"
Moritz
maxim_k
Hi @moritz_kirschbaumAYZZ7 ,
Where exactly do you see Autodesk folder?
There are also another instructions about clean uninstall AutoCAD for Mac:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Clean-Uninstall-fo...
Try to use them.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Observer
Observer
Hello
the folder Autodesk-folder appears in /library/Application Support/
I tried all the steps and deleted all com.autodesk, com.alias files and the folder but after restarting the system the folder appears again and the Autodesk Identity Manager-process starts again.
maxim_k
Have you tried to disable background tasks for AutoCAD and Autodesk in macOS System Settings -> General -> Login Items and restarting your Mac  before removing Autodesk folder:
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Observer
Observer
my system is MacOS Big Sur 11.7.10 so the Login-Items-Menu looks a little bit different, but there is nothing from Autodesk
maxim_k
You can try to ask your question here:
Subscription, Installation and Licensing
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
