Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Uninstall of Autodesk does not work
moritz_kirschbaumAYZZ7
Observer Observer
Observer
Observer
Hello community,
I don't need AutoCAD for mac anymore and so i tried de uninstall. I did all steps which are published here:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Clean-uninstall-of...
but i does not work properly.
After restart, there appears still an "Autodesk" folder and an process named AdskAccessServiceHost and the Licensing manager. Everytime I quit the process, it starts again a few minutes later and I get the message "AdskUtil ended unexpectedly"
Moritz
maxim_k
Hi @moritz_kirschbaumAYZZ7 ,
Where exactly do you see Autodesk folder?
There are also another instructions about clean uninstall AutoCAD for Mac:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Clean-Uninstall-fo...
Try to use them.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Observer
Observer
Hello
the folder Autodesk-folder appears in /library/Application Support/
I tried all the steps and deleted all com.autodesk, com.alias files and the folder but after restarting the system the folder appears again and the Autodesk Identity Manager-process starts again.
maxim_k
Have you tried to disable background tasks for AutoCAD and Autodesk in macOS System Settings -> General -> Login Items and restarting your Mac  before removing Autodesk folder:
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Observer
Observer
my system is MacOS Big Sur 11.7.10 so the Login-Items-Menu looks a little bit different, but there is nothing from Autodesk
Bildschirmfoto 2024-03-23 um 11.19.43.pngBildschirmfoto 2024-03-23 um 11.19.43.png
maxim_k
You can try to ask your question here:
Subscription, Installation and Licensing
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
