When I attempt to use the EXTRUDE or PRESSPULL commands, they both either don't recognize the lines or throw an error saying "Cannot sweep or extrude an object of this type." The DXF was exported from Inkscape where I drew it as an SVG. I've tried exploding the block into splines as well, but this does not work either. The SVG and .dwg I'm working with are attached.
The topic title has been edited to improve findability by @alina.balkanskaia. Original: Unable to extrude from an imported DXF
Hi @ndesaraju ,
I exploded the block in your drawing and used JOIN command to join splines.
Then I was able to use EXTRUDE command - see attached DWG.
Hello, @ndesaraju! Thank you for posting your question in Autodesk Community!
I see you've got a couple of recommendations. Please, click the "Solution" button for the most helpful answer. So that other users can benefit from this information.
