Trouble with lines and measurements
hbpowers
hbpowers
Community Visitor
Community Visitor
When I try to create lines or shapes the measurements appear not in whole numbers. I was enrolled in a course to learn CAD for interior design and this held me back from learning the rest of the material. I attached an image of what I see from a simple line. My professor was at a loss and we did quite a bit of troubleshooting.
pendean
Community Legend
Community Legend
@hbpowers This means you are starting this LINE command somewhere around the planet Jupiter instead of much closer to the 0,0,0  start point of your open DWG file.
Did you receive this file from someone else perhaps?
hbpowers
Community Visitor
Community Visitor
Yes, this file was sent to the class but no one else had this issue.
Interesting, during troubleshooting we moved the starting point to the axis. Is there another way to check that? I only have the files I was sent to go off of. I only got 2 weeks into the course before I had to re-enroll in the spring so I am pretty new to CAD.
paullimapa
If your prof cannot figure this out then it’s time to drop this institution and go somewhere else that’s more knowledgeable
Paul Li
IT Specialist
@The Office
pendean
Community Legend
Community Legend
@hbpowers wrote:
Yes, this file was sent to the class but no one else had this issue....
So everyone else, when you INSERT your DWG file into theirs, show up in the same exact spot, or close enough, or is yours so far far away it goes back to what I wrote as your issue?
@hbpowers wrote:
...Interesting, during troubleshooting we moved the starting point to the axis...D.
Isn't that pretty much what I suggested? or is it different? You'll need to share your DWG file here then if you remain unsure about it all.
We also need screenshots of the ABOUT command from inside your AutoCAD: and confirm your OS please.
