Thicken Command for AutoCAD Mac
hrdodia
hrdodia
Hello everyone,
I'm trying to use the Thicken command in AutoCAD for Mac to add thickness to a cylinder. However, I keep receiving an error message stating that "no surface was selected," even though I have selected the surface.
Has anyone experienced a similar issue or know how to resolve this? I'd really appreciate any help or suggestions.
Thank you in advance!
Best regards
maxim_k
Hi @hrdodia ,
Are you sure that the cylinder you are trying to convert with THICKEN command is a surface object.
What do you see in the Properties Palette when you select the cylinder?
Can you share your drawing here?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
hrdodia
Hey @maxim_k
I have sent you my drawing. I am new to AutoCAD 3d, please can you help with it?
maxim_k
Hi @hrdodia ,
Both cylinders are already 3D Solids, so you cannot use THICKEN command to convert them into a 3D solid with a specified thickness.
What results do you want to achieve?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
maxim_k
I can suppose that you want to convert cylinders to tubes.
So you need at first explode 3D Solids (cylinders) with EXPLODE command, then convert tube surfaces to solids with thickness with THICKEN command.
See attached drawing
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
hrdodia
Thank you, I understood why I was not able to use the THICKEN command. After using the EXPLODE command, I was able to solve the problem. Appreciate your prompt response. Thank you.
