AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Subtracting Objects
1 REPLY 1
337 Views, 1 Reply
Subtracting Objects
I have a drawing I'm working on and I'm needing to subtract pieces to make the cutouts in the item I'm designing. I'm 2/3 of the way done and it decided not to subtract the rest of my pieces... It extrudes them like normal but will not remove them. When I copy and paste the 2D items, Extrude them and build a box around them, they subtract just fine... Does anyone know why this would be happening or how to fix it????
1 REPLY 1
maxim_k
Please check that 3D solids in your drawing doesn't include Solid History:
Remove the History of a Composite Object
    1.    If the Properties palette is not displayed, select any object. Right-click the object and select Properties.
    2.    Select a composite 3D solid.
    3.    On the Properties palette, Solid History area, under History, select None.
Also check that system variable SOLIDHIST=0
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
