Special characters on Mac
devlinkieran
Observer Observer
Message 1 of 13
devlinkieran
Observer
Observer
I'm using Mac Auto CAD and having trouble getting special characters to display.
I'm trying to use counterbore and depth symbols but just get square symbols (unrecognised symbol)
What do I need to do to get these to display properly?
Replies (12)
Message 2 of 13
imadHabash
Symbols are not supported in vertical text .. Try to read this link that may help. >> Click <<
Imad Habash
Message 3 of 13
devlinkieran
Observer
Observer
Unfortunately there wasn't any help on that page.
I'm using horizontal text - all the text displays except the special characters
Message 4 of 13
maxim_k
Hi @devlinkieran ,
To display correctly special symbols in MTEXT, you need to use Arial Unicode MS font.
To insert special symbol - use this button in Text Editor Visor:
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 13
devlinkieran
Observer
Observer
This works!
Thanks so much
Message 6 of 13
conradrobert_weston
Observer
Observer
I'm working with AutoCAD 2025 for Mac, and when I click on the "@" button, nothing comes up. I don't know if this is a bug or if it's an issue with my computer. I tried reopening AutoCAD, but that didn't seem to change anything. Any thoughts?
Message 7 of 13
maxim_k
Hi @conradrobert_weston ,
Please specify macOS version installed on your Mac.
Have you tried to Reset AutoCAD to defaults?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 8 of 13
conradrobert_weston
Observer
Observer
I have the Sequoia 15.6.1 operating system on a MacBook Air with the M2 processor.
Message 9 of 13
maxim_k
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 10 of 13
conradrobert_weston
Observer
Observer
Yes. When I click the "@" button on the text edit pop-up, the dropdown menu opens, but when I click on the "other" button at the bottom of the menu, nothing comes up. My current workaround is installing the GDT font in the Font Book app, then copying the character into AutoCAD.
Message 11 of 13
maxim_k
Do you have any app running on your Mac that replaces the standard input source switching function?
For example Keyboard Switcheroo
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 12 of 13
conradrobert_weston
Observer
Observer
Not that I know of.
Message 13 of 13
maxim_k
I asked about this because I decided to check if there is a problem with the Character Viewer launching with @->Other in AutoCAD
I tried it, and it didn't work for me either. Plus "Ctrl+Cmd+Spacebar" shortcut refused to open Character Viewer inside MTEXT command in AutoCAD.
Then I started to figure out what the problem was.
I disabled the Switcheroo application and turned on Input menu in the menu bar.
"Ctrl+Cmd+Spacebar" shortcut started to work inside AutoCAD and now I'm able to use  @->Other inside MTEXT editor in AutoCAD.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
