Dimension numbers with Tahoe
consultasbarcos
Message 1 of 17
consultasbarcos
With autocad 2026.1 LT for mac, I have a problem with dimensions, if i do a zoom (normal view) i lost the numbers in dimensions, i can see arrowa and lines but not the numbers.
Replies (16)
Message 2 of 17
maxim_k
Hi @consultasbarcos ,
Do you have this problem in all drawings? Even in newly created?
Have you checked the text height in the dimension style?
If it is a specific drawing, can you share it here?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 17
consultasbarcos
I have discovered that if I switch to an SHX font, the text is visible. I think the problem is with TTF fonts. They are installed on the system, but AutoCAD 2026Lt does not recognize them. However, they work with version 2025.
I have even set GPUTEXT2D to 0, and it still does not work.
Message 4 of 17
maxim_k
What TTF font (which is invisible) do you use in the Text Style for Dimension style?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 17
consultasbarcos
I have tried all the TTF fonts, and they are all invisible; only SHX fonts are visible.
They are invisible for dimensions as well as for text only.
Message 6 of 17
maxim_k
What Mac model do you have?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 17
consultasbarcos
MacBook Pro (M1), with Tahoe 26.0.1
Message 8 of 17
maxim_k
That is really strange.
 The text is not visible in sizes, but if you create regular text - it is visible. Did I understand correctly?
Can you attach here one of your drawings where dimension text is not visible?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 9 of 17
consultasbarcos
If I use a TTF font, the text isn't visible in either the dimensions or the normal text.
The text is only visible in both cases when I use an SHX font.
Message 10 of 17
maxim_k
I think there could be a problem with AvantGarde BT fonts you are using for text style:
 Have you tried to change them to another TTF font (not SHX, but TTF), for example to Arial?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 11 of 17
consultasbarcos
Yes, I've tried all the TTF fonts, and it's always the same problem, the text isn't visible with any TTF.
Message 12 of 17
maxim_k
@consultasbarcos ,
There is another system variable you can try to change - DTTEXT
Try to set it to 0 (zero)
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 13 of 17
consultasbarcos
No change when setting DTTEXT=0, texts are still not visible.
Message 14 of 17
maxim_k
You wrote that in the 2025 version you can see text created using TTF fonts.
What settings do you have on this tab of AutoCAD Preferences?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 15 of 17
consultasbarcos
I have this: Change Graphic engine: OpenGL Core Profile
But i don´t find this option in 2026 version
PD: thanks a lot for your help
Message 16 of 17
maxim_k
@consultasbarcos ,
Yes, this option was deprecated in 2026 version.
Metal Graphics engine in AutoCAD should work fine on MacBook Pro with M1 chip. It is really strange that you have this problem on your Mac.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 17 of 17
consultasbarcos
I just found a solution. I reset AutoCAD 2026 but didn't import the settings from AutoCAD 2025, and now the text is visible.
Thank you very much for your time and help.
