Some shapes extrude, some don't. What am I doing wrong?
davidsemail916
davidsemail916
Screen Shot 2021-04-19 at 6.08.28 PM.pngBuilt everything using the arc and line tools while in the top view.  Some shapes extrude and some don't.  Where did I go wrong?  Any advice would be appreciated.
David
  • Help
ennujozlagam
try the file attached. i did use boundary command and pick inside the objects and see if helps. thanks
imadHabash
 Click on below image to see how PRESSPULL (Command) works fine .
Imad Habash
davidsemail916
Oh wow, it worked!  thank you!
Can you tell me exactly what you did and what I did wrong to prevent any future reoccurrence?
ennujozlagam
i just make a boundary command > pick points inside the object to create a boundary line of the profile and extrude. it could be your lines are not close enough to extrude? thanks
