Hello -
I have draw a mechanical drawing in layout format and need to insert that drawing on a title block which opens up as a separate file. Can anyone please help me on how to do it?
Many thanks
Welcome to Autodesk Forums!
Hi @Anonymous ,
Do you mean you drew in Paper space (Layout)? If yes, then you need at first to move everything to Model space.
After that you will be able to insert Title block to Layout from separate file - your can copy and paste it.
Now - create viewports in the Layout and adjust its scales.
Hi Maxim -
Thanks so much. My drawing was in model space and I copied it over to the Title block, and it worked.
Thanks again
