AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
saved file wont shows the correct date
14 REPLIES 14
Message 1 of 15
desmond.cheong
517 Views, 14 Replies
Version: Autocad LT 2024 Mac
Recently I just switched to Mac and I am facing this issue that my saved drawings somehow will not reflect the proper saved date but instead, it was somehow set to 1 Jan 1970.
14 REPLIES 14
Message 2 of 15
paullimapa
in reply to: desmond.cheong
May want to post in the Mac forum to get better feedback
Paul Li
IT Specialist
@The Office
Message 3 of 15
maxim_k
Hi @desmond.cheong ,
Are you sure your macOS system time is set to the correct date and time?
Where you save your drawings?
If they are on a NAS - check time settings on it.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 4 of 15
pendean
@desmond.cheong wrote:
...Recently I just switched to Mac and I am facing this issue that my saved drawings somehow will not reflect the proper saved date but instead, it was somehow set to 1 Jan 1970.
What about all other files types from other programs that you save to the same location as your DWG file, do they also reflect the 1970 default date stamp?
Message 5 of 15
desmond.cheong
in reply to: maxim_k
Hi Maxim Kanaev,
Yes, the Mac OS has the set the the actual date and time.
As for the file I save it to my Mac and then it links to Onedrive. I could not find any setting on the time setting for onedrive and I have other files that work perfectly fine hence it led me to think it would be the AutoCad LT issue somehow but I might be wrong.
Message 6 of 15
desmond.cheong
in reply to: pendean
Hi Pendean,
Other types of files that I work with don't have this issue. I had some Adobe Photoshop and Illustrator files that worked just fine. I do find it weird it only happens to CAD files somehow.
Message 7 of 15
maxim_k
Just tried to save a drawing to OneDrive folder on my Mac and the date is correct.
Can you share the screenshot of the OneDrive folder where you save your drawing? Please set the view in Finder to "List" view, like this one:
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 8 of 15
desmond.cheong
Hi @maxim_k
Kindly refer to the screenshot below. As you can see, all the files from previous years were saved from my previous computer. When I use the template_2023 to create an additional copy for 2024, it fails to sync or save because the date has been modified.
Thank you in advance!
Message 9 of 15
maxim_k
Hi Desmond,
Do you save this template drawing to OneDrive folder directly from AutoCAD?
Have you tried to save the template outside AutoCAD and then copy it to OneDrive folder?
Have you installed all the latest updates for OneDrive?
I think this could be OneDrive issue.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 10 of 15
pendean
...Kindly refer to the screenshot below. As you can see, all the files from previous years were saved from my previous computer....
Your file failed to sync, technically it does not exist on OneDrive at the moment of the screenshot
You have a OneDrive sync problem: this has nothing to do with the AutoCAD program.
Message 11 of 15
desmond.cheong
Hi @maxim_k  & @pendean
It works after I reinstalled the Onedrive software. Thank you for your patience and assistance!
Message 12 of 15
wei503
This issue is not specific to Onedrive. It is fixed in 2025.0.1 hotfix, which was just released.
@desmond.cheong I would suggest you to upgrade to 2025, and install the 2025.0.1 hotfix.
Wei Ma
AutoCAD for Mac QA Manager
Message 13 of 15
Hi @desmond.cheong I am facing the same issue. Were you able to find a fix for this?
Message 14 of 15
pendean
in reply to: manthanmchandak17
Message 15 of 15
Hi @manthanmchandak17
Yes the solution that work for me is to update it to 2025 and install the hotfix then it will resolve the problem, but those file that come with the issue you need to open and resave it after you install the hotfix for it to works.
Hope it helps!
Technology Administrators
