Save Issues in AutoCAD for Mac
Message 1 of 17
My ACAD LT will not "Save As" to specified folder in "Documents". It will only Save As to my Desktop? Not sure what the issue is (Is it bc I'm working in the "free" trial period?) I've already re-installed software, careful to follow all download instructions. I am able to Save As to my Desktop though? Anyone else had this issue? I'm using Mac OS Mojave on a 2018 MacBook Pro.
Thanks much.
Kevin d.
Replies (16)
Message 2 of 17
maxim_k
Welcome to Autodesk Forums!
You are not able to save to specific folder inside Documents folder or to any folder inside Documents folder?
If the first - then this could be permissions problem, if the second - verify the name of the folde you are not able to save drawings to.
And please specify AutoCAD LT version you are using.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 17
maxim_k
An additional question:
What do you see, when you are trying to save drawing to the folder inside Documents folder?
An alert from AutoCAD?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 4 of 17
I am having the same issues. Using AutoCAD2019 on MacOS.
When I click Save As the dialog box disappears and reappears. I keep clicking Save As and it doesn't save.... unless I save to the Desktop...
Message 5 of 17
maxim_k
Hi Matthew,
What macOS version installed on your Mac?
If it is macOS Catalina (10.15) - have you installed >>>>this<<< Update?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 6 of 17
I'm running Mojave
My AutoCAD is "Up to date"!
Message 7 of 17
maxim_k
So there could be some permission issues.
Do you have this issue from the very beginning?
If it starts suddenly - have you tried to Reset AutoCAD?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 8 of 17
I'm having the same issue with my Autocad version 2018. I'm using macOS mojave. I have trie the methods above. No luck.
Message 9 of 17
maxim_k
Hi @Anonymous ,
Can you save your drawings to some folder on your Mac? Or you can't save them at all?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 10 of 17
Yes I can. But not to a folder where the same drawing exists. If i want to
change the name and save it to the same folder its not possible.
Message 11 of 17
pendean
Community Legend
Community Legend
@Anonymous Is there an error message?
Message 12 of 17
maxim_k
>>>>>If i want to change the name and save it to the same folder its not possible.
What if you change name and try save to another folder?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 13 of 17
Not working.
Message 14 of 17
The dialogue box keeps reappearing to select a folder in which I need to
save.
Message 15 of 17
pendean
Community Legend
Community Legend
@Anonymous Can I impose on you to show us screenshots of that pop-up message, as well as the location of your files in Finder?
Can you copy or add files to that folder in Finder by chance?
Where are you saving the file? Somewhere in your home folder, or outside your home folder? If it is in your home folder, you seem to have some permission problems on your home or that folder.
In Finder, open the folder where you are trying to save the file and Get Info (cmd-I). What does it show for the permissions at the bottom of the window?
Message 16 of 17
The permissions given are for reading and writing but unable to make the
necessary changes.
Message 17 of 17
maxim_k
@Anonymous ,
Can you attach screenshot of Save As window, when you are trying to save drawing with new name?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
