I've added some PAT files that i thought would help save me time but are creating more issues than helping out.
Im currently looking for a way to remove them from my CAD.
When i click hatch they pop up with an error see screenshot attached.
I've tried removing the problematic hatches from Their folder on the local server. I've double checked that they are not in the ~/Library/Application Support/Autodesk/roaming/AutoCAD LT 2014 Standalone/R19.1/enu/Support" folder as per Maxim's thread here - https://forums.autodesk.com/t5/autocad-for-mac-forum/new-hatch-can-t-find-file/m-p/5470101
However as you can see in the screenshot the top right is that folder and does not contain any extra pat files. but i still get the errors when selecting hatches from the autocad window
also attached a Zip of the problematic hatches. which i tried to remove
Version - AutoCad Mac 2016
Solved by maxim_k. Go to Solution.
