Problem with Xref update via hyperlink in popup. autocad 2026 trial to macOS.
Guicsr
Guicsr
When I update one dwg, in the other a popin appeared saying to update the xref, a blue hyper link appears
Underlined, with a little square to click to compare with the previous drawing, when I click on it, instead of updating the xref it opens a SECURELOAD command, I already put it as 0, but it's no use, whenever the popin appears to click it opens this command, is there any way to fix this bug?
maxim_k
Hi @Guicsr ,
Looks like it is a bug (defect) in the Italian localization of AutoCAD 2026 for Mac.
When you select "Ricarica for....." in the pop-up window, AutoCAD uses "-XREF" command instead of "_-XREF" (or "-XRIF") and writes "Comando sconosciuto "-XREF". Premere F1 per la Guida." at the command window. Then it interpret  the command option "_reload" as "SECURELOAD".
So if you need to reload Xref after you edit it, you need manually reload Xref.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Guicsr
I'm using autocad in English, how could I give a localization error in Italian?
maxim_k
Sorry, my bad. I thought that you are using Italian localization.
But when I use English language for user interface and command input, I don't see such problem. This is what I see at the Command prompt when I select "Reload ...":
In your case you see:
Have you had this problem from the beginning?
Have you tried to use -XREF command by typing its name at the Command window and hitting Return?
Have you tried to Reset AutoCAD?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
paullimapa
try at the command prompt the following:
REDEFINE
XREF
REDEFINE
-XREF
Paul Li
IT Specialist
@The Office
Guicsr
In autocad 2025 -xref exists, a menu appears, but in cad 2026 it says that the -xref command does not exist
Guicsr
It didn't work, cad 2026 doesn't even recognize the -xref command, but in cad 2025 it did
