I have a problem with the letter "S" , Whenever I type it the following letter types directly over it!
Have you ever seen this? see attached drawing (inside white box)
Started this morning!
Solved by pendean. Go to Solution.
no issue opening this dwg on Windows version of AutoCAD...have you tried shutting down your Mac and starting it up again?
@JEFFJW9BB wrote:I have a problem with the letter "S" , Whenever I type it the following letter types directly over it!
Greetings: did you intend to post a screenshot of what you see? There is nothing wrong inside your DWG file here either
Glad to have helped…cheers!!!
