Printing/page set up not displaying correctly
Message 1 of 9
Whenever i attempt to print the print window opens then when i click on "Edit Page Setup..." the Page Setup-Layout1" does no longer display correctly and I can not choose any options as I can not see the full window
any suggestions to fix the problem would be greatly appreciated.
Michela
Replies (8)
Message 2 of 9
Emmsleys
HI @Anonymous,
What AutoCAD release are you working in? 2015, 2016?
What Mac OS are running?
As a test you can try logging in as a separate/new user on your Mac to see if this issue happens in that profile with AutoCAD in default settings.
Sarah Emmsley
Technical Support Specialist
Message 3 of 9
I have a Mac OS X Yosemite Version 10.10.5
and Autocad LT 2013
I have tried as you suggested to login as a guest and it works thanks. But it still does not work on my proper log in where i have all my files.
[cid:08D4B039-AC1C-4704-949C-4324EDF83AAC@lan]
102 Belgrave Road
London SW1V 2BJ
t +44 207 112 7534
m+4407899771492
www.mb-ds.com
Message 4 of 9
maxim_k
At first you need to install all updates for AutoCAD 2013, the last one add compatability with OS X 10.10
Than you need to try to reset AutoCAD from Application tab of AutoCAD preferences.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 9
Emmsleys
Thanks for getting back to me.
Okay since it was able to work effectively in a new user login I would recommend you reset your AutoCAD settings back to default in your user profile.
Apply any updates that you might have missed as suggested in a previous post by Maxim.
SP 1
SP 2
SP 3
Sarah Emmsley
Message 6 of 9
Thank you for your suggestions that I have all tried but they did not fix the problem they will not allow any upgrade
I probably try to re install auto Cad? Can that be a way?
SP 1
SP 2
SP 3
Message 7 of 9
wei503
Here is the page to re-install AutoCAD LT 2013 for Mac, with SP3.
https://knowledge.autodesk.com/support/autocad-lt-for-mac/downloads/caas/downloads/content/autocad-l...
Wei
Wei Ma
AutoCAD QA Manager
Message 8 of 9
maxim_k
Have you tried to reset AutoCAD instead of reinstalling it?
And one more question : are you sure you have OS X 10.10.5.? Can it be 10.11.5.?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 9 of 9
Emmsleys
@Anonymous,
Circling back on your thread, were you able to try any of the suggestions made after my post? Did any of them help with your problem?
Sarah Emmsley
