Raster image path
Raster image path
Message 1 of 16
Raster image path
Good day!
After inserting image into a drawing (image in stamp) I place my drawing with image at my server in the internet (some hosting).
Unfortunately the drawing lost the image and it shows only path. What can a decision be?
Thank you
Maxim
Replies (15)
Message 2 of 16
rkmcswain
Did you download the drawing and image from the Internet location to a local machine and try to open it from there?
Or are you opening the drawing from the Internet location?
R.K. McSwain     | CADpanacea | on twitter
Message 3 of 16
maxim_k
Welcome to Autodesk Forums!
Hi Maxim,
Which AutoCAD version do you have?
I think you need at first to try to put DWG and raster image to the same folder on the server, this should resolve the issue.
You can also edit / save path to the image file in the External references palette.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 4 of 16
I am opening the drawing from the internet location. I put the raster into main folder.
Max
Message 5 of 16
Hi!
I have got AutoCAD for Mac 2015
 - it does not work.
You can also edit / save path to the image file in the External references palette. - How can I edit the drawing in DWG TrueView 2017? I do all operations in Parallels.
Max
Message 6 of 16
maxim_k
AutoCAD for Mac 2015 or TrueView 2017?
So after all, can you explain what exactly you are using?
I think you can change path to the external referenced file only in AutoCAD, but not in DWG viewer.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 16
maxim_k
If you want to view correctly DWG file in Trueview, you need to prepare it in AutoCAD.
Start on your local drive
- put rate image and DWG file to the same folder
- attach raster image to the drawing with "no path" option (you can find this option in the "Attach external file" dialog)
- save DWG
- copy DWG and raster image to the same folder on the external storage
- try to open in DWG viewer application - Trueview in your case.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 8 of 16
rkmcswain
Sounds like @Anonymous is creating the drawing using AutoCAD, then placing it and the image on a server somewhere and then using Trueview to open and view it.
Message 9 of 16
maxim_k
Yes, I thought so.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 10 of 16
Hi!
I am using AutoCAD for Mac for drawing but my colleagues have Windows computers and use DWG Viewer.
Max
Message 11 of 16
maxim_k
So, as I wrote before - try to use "no path" option when you attach image on your Mac.
Max
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 12 of 16
Hi!
It does not work - see attached file. But what is strange - in small window in preview it is ok
Max
Message 13 of 16
maxim_k
А переименовать файл изображения, чтобы не было кириллицы пробовали?
Вполне вероятно, что интернет диск неверно транслирует имя файла, либо Trueview как-то не так понимает его.
Тем более, что речь идёт о различных файловых системах и различных расширенных котировках, которые присутствуют в Вашем случае - Mac OS, Windows, и наверно, - Unix на Интернет сервере.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 14 of 16
Привет! Спасибо, заработало, но файл видит растр только в паралельс на рабочем столе, на серваке не видит - растр куда положить - в ту же папку (не работает) или куда-то еще?
Максим
Message 15 of 16
maxim_k
А что за сервер используется?
Растр я предлагаю положит в одну папку (на сервере) вместе с DWG файлом.
А если растр присоединен в AutoCAD для Windows? Тогда он виден при использовании TrueView? Может быть это проблема TrueView? Сам никогда не использовал эту программу, то есть использовал, но очень давно - в начале 2000-х, и с прикрепленными растрами не экспериментировал.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 16 of 16
rkmcswain
The preview thumbnail is simply a screencap when the file was last saved.
It's not a live preview of the file and it's references.
