PRINT
PRINT
earthsquare
Message 1 of 20
PRINT
earthsquare
How to create pdf files, size larger than A3
I have a printer connected, which supports sheets up to A3 size.
Regards
Sreejith.S
Sreejith.S
Landscape Architect
Replies (19)
Message 2 of 20
maxim_k
You can create custom paper size and use it to output to PDF:
http://autodesk.blogs.com/between_the_lines/2011/01/quick-tutorial-plotting-custom-paper-sizes-in-au...
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 20
earthsquare
Thanks.
That was very simple. Not sure how I missed it.
Regards
Sreejith. S
Sreejith.S
Landscape Architect
Message 4 of 20
earthsquare
Hi
Going back to the issue we discussed few months ago, I am able to add A2 and A1 size pages on the 'edit page setup' box but when I get back to the print dialogue box, the A2 and A1 size appears dim and cannot be selected. A$ gets selected automatically.
Any work around ?
Thanks in advance.
Regards
Sreejith. S
Sreejith.S
Landscape Architect
Message 5 of 20
maxim_k
Hi Sreejith,
Can you post screenshot of the Print dialog?
What if you set Page setup with custom paper size current in Page Setup Manager for the layout you want to print?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 6 of 20
earthsquare
Hi Maxim,
Sorry for the late reply. Have been travelling.
Please find the attached screen shots.
Screen Shot 2017-03-24 at 11.15.48 AM.pngScreen Shot 2017-03-24 at 11.16.07 AM.png
Regards
Sreejith
Sreejith.S
Landscape Architect
Message 7 of 20
earthsquare
Hi Maxim,
Just bringing to your kind attention about the screenshots I have shared.
Regards
Sreejith.S
Landscape Architect
Message 8 of 20
maxim_k
Hi Sreejith,
I'm not absolutely sure, but maybe custom paper sizes are not available because the "Presets" option in Print dialog selected as "Last used settings" instead of "Default settings".
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 9 of 20
earthsquare
Hi Maxim,
Tried with 'Default settings', still no luck.
Regards
Sreejith.S
Landscape Architect
Message 10 of 20
maxim_k
Do you use Page Setup Manager to change and save Page Setup for the drawing? Or you are using "Edit page setup" button from "Print" dialog?
If latter, than try to edit, save and "Set current" Page Setup with custom paper size in Page Setup Manager at first, than use Print window.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 11 of 20
earthsquare
I used to use 'edit page setup', tried your suggestion it was not working.
Now then I tried the 'page setup manager', it works....
Thanks.
I hope it works in other drawings too.
Regards
Sreejith. S
Sreejith.S
Landscape Architect
Message 12 of 20
maxim_k
Should work.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 13 of 20
earthsquare
Not working Smiley Sad
Sreejith.S
Landscape Architect
Message 14 of 20
maxim_k
"Not working" - what?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 15 of 20
earthsquare
unfortunately no.
I tried with 'new page setup'...
just not able to use it in print dialogue box.
Sreejith.S
Principal Landscape Architect
National Executive Council Member Indian Society of Landscape Architects
Secretary Indian Society of Landscape Architects, Kerala Chapter
Associate Member Indian Institute of Architects
Registered Member Council of Architecture
facebook twitter
instagram
“Be a yardstick of quality. Some people aren’t used to an environment where
excellence is expected.” » Steve Jobs
Sreejith.S
Landscape Architect
Message 16 of 20
maxim_k
Do you mean you don't see the page setup (named, created in Page Setup Manager) in Print window?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 17 of 20
earthsquare
Hi Maxim,
I am able to use the new page setup in the print dialogue box... but can't
pick the A2 size which i need.
Regards
Sreejith.S
facebook twitter
instagram
Sreejith.S
Landscape Architect
Message 18 of 20
maxim_k
So you are not able to pick A2 size in Print dialog (again).
But are you able to select it when you create page setup in Page Setup manager?
If you are able to select it in Page Setup manager and than save this page setup by giving it specific name, than in Print dialog you simply select saved page setup (by its name) and you don't need to change page size as it is already saved with named page setup.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 19 of 20
earthsquare
Hi Maxim,
I tried setting up a new page, which i have named A2, using the pagesetupmanager.
paper size selected is A2......
Now when i comeback to the layout and try to take print.
edit pages up and select A2 page setup......
I am not able to select the paper size A2 😞
Regards
Sreejith.S
Landscape Architect
Message 20 of 20
earthsquare
Hi Maxim,
Continuing from the last message. When I select the 'other' option as seen in the image attached, it prints to A2 size even when the A2 size sheets are not displayed.
I think this solves the issue.
Thanks for following it up.
Regards
Sreejith.S
Sreejith.S
Landscape Architect
