- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi!
I'm setting up a set of construction documents and having some issues. When I plot some sheets as PDF's everything works fine and then in others, the line weights look COMPLETELY OFF.
I'm attaching two dwgs that use the same border and layers so you can see my issue. A1.00 plots everything well, but A1.01 is giving me these heavy line weights. In the zip folder you'll see the CTB file!
If anyone can look at this and help me that would be great ! thanks!
