Plotting with same CTB file looks completely different on two files
velvethKKLQ3
velvethKKLQ3
Hi!
I'm setting up a set of construction documents and having some issues. When I plot some sheets as PDF's everything works fine and then in others, the line weights look COMPLETELY OFF.
I'm attaching two dwgs that use the same border and layers so you can see my issue. A1.00 plots everything well, but A1.01 is giving me these heavy line weights. In the zip folder you'll see the CTB file!
If anyone can look at this and help me that would be great ! thanks!
0 Me gusta
Responder
Soluciones aceptadas (1)
302 Vistas
2 Respuestas
Respuestas (2)
maxim_k
Hi @velvethKKLQ3 ,
I cannot look at your drawings at the moment, but please check if you have "Scale line weights" option enabled for A1.01 layout. If yes - turn it off and test plotting.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
maxim_k
Solución aceptada
@velvethKKLQ3 ,
Yes, I was correct in my previous post.
Uncheck Scale lineweights option in Page Setup for A1.01 layout:
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
