Hi all,
I just recently switched from PC to CAD for MAC and am loving it. One of my favorite .lisp files that I routinly use is giving me a bit of concern though. I load the PLDiet.lisp and that goes smoothly, i even go through all the prompts till the point of picking a pollyline. after that it just stops working, and if i escape i get the following message:
Error: bad argument type: lselsetp nil
Cannot invoke (command) from *error* without prior call to (*push-error-using-command*).
Converting (command) calls to (command-s) is recommended.
Any and all help appreciated ๐
Solved by maxim_k. Go to Solution.
Hi @chloeleyba8NWHJ ,
PLDIET.lsp contains vlax- functions that are not available on Mac, that is why you cannot use it in AutoCAD for Mac.
