I am unable to draw straight lines (please see the attached photo) using the ortho mode. Instead of being at a right angle (0 degrees) it is set at 332 degrees, setting all of my work at a wrong angle. I have tried resetting Ortho using Snappang, Viewtwist and UCS World. However the problem is still not solved. I have read many forums and watched tutorials and still can't figure it out. Any advice would be much appreciated as this is evidently setting me behind in my work.
Thanks!
Solved by maxim_k. Go to Solution.
Welcome to Autodesk Forums!
Hi Rachel,
Verify that you have correct settings for Base Angle: use menu Format -> Units and:
You can also attach your drawing, I can look at it if my suggestion won't help.
Maxim
Hi Maxim,
Thank you so much! I managed to change the Base Angle back to 0 now under your instruction!
You have make my day!
Rachel
