AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Ortho angle Incorrect setting
2 REPLIES 2
rachelwong007
7118 Views, 2 Replies
I am unable to draw straight lines (please see the attached photo) using the ortho mode. Instead of being at a right angle (0 degrees) it is set at 332 degrees, setting all of my work at a wrong angle. I have tried resetting Ortho using Snappang, Viewtwist and UCS World. However the problem is still not solved. I have read many forums and watched tutorials and still can't figure it out. Any advice would be much appreciated as this is evidently setting me behind in my work.
Thanks!
2 REPLIES 2
maxim_k
in reply to: rachelwong007
Welcome to Autodesk Forums!
Hi Rachel,
Verify that you have correct settings for Base Angle: use menu Format -> Units and:
You can also attach your drawing, I can look at it if my suggestion won't help.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
rachelwong007
in reply to: maxim_k
Hi Maxim,
Thank you so much! I managed to change the Base Angle back to 0 now under your instruction!
You have make my day! Smiley Very Happy
Rachel
