'OPTIONS / PREFERENCES' Command is Unknown in Autocad
rb4767
Message 1 of 9
rb4767
Hi all,
I'm experiencing a major issue with my AutoCad.
Some commands are not working at all, neither when I type them out or when I click on the respective icons. Whenever I try, the software says "Unknown Command. Press F1 for Help". These include MATCHPROP, MTEDIT, UNITS, BLOCK EDITOR, and OPTIONS/PREFERENCES. Most of the solutions found online state that you need to change settings in the OPTIONS Dialog Menu to fix the other commands, but I cant open that menu because OPTIONS is one of the commands that need fixing.
I tried resetting Autocad to default several times, as well as uninstall and install anew.
I cannot think of a reason why this happened, other than my subscription was ending, and I renewed it earlier because it was acting up.
Would greatly appreciate any insight on this, as I'm growing pretty frustrated and the support staff I contacted so far was not helpful.
Replies (8)
Message 2 of 9
maxim_k
Hi @rb4767 ,
Please specify AutoCAD for Mac version you are using and macOS version installed on your Mac.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 9
rb4767
macOS Monterey version 12.4
Autocad 2024; says product version U.61.M.182
Message 4 of 9
wei503
Does it work if you type a underline before the command, for example "_mtedit"?
Wei Ma
AutoCAD QA Manager
Message 5 of 9
maxim_k
Hi @rb4767 ,
Can you share screenshot of the command window when you are trying to use one of the commands you mentioned in your initial post?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 6 of 9
rb4767
@maxim_k This is what it looks like. Hope it helps; let me know if I can provide anything else.
Message 7 of 9
rb4767
No, it does not (see reply to maxim_k providing a screenshot).
Message 8 of 9
rb4767
I was able to solve it by deleting the install folder (Library>Application Support>Autodesk) completely alongside uninstalling. When installing again, the problem wasnt there anymore. Im unsure why this worked as opposed to resetting to default or uninstalling without retaining preferences but oh well.
Message 9 of 9
MNunezArditecnica
Community Visitor
Community Visitor
I found my self in the same issue, with the same commands.
This Autodesk help page solved it:
"Unknown command" when entering commands in AutoCAD products
Especifically:
AutoCAD product settings and configuration
  • For all AutoCAD products except AutoCAD LT, check ObjectARX loading:
    1. Enter OPTIONS on the command line or click Options under the application menu.
    2. Click the Open and Save tab.
    3. Change "Demand load ObjectARX apps" to "Object Detect & Command Invoke."
    4. Click OK on the Options window.
