'OPTIONS / PREFERENCES' Command is Unknown in Autocad
rb4767
rb4767
Hi all,
I'm experiencing a major issue with my AutoCad.
Some commands are not working at all, neither when I type them out or when I click on the respective icons. Whenever I try, the software says "Unknown Command. Press F1 for Help". These include MATCHPROP, MTEDIT, UNITS, BLOCK EDITOR, and OPTIONS/PREFERENCES. Most of the solutions found online state that you need to change settings in the OPTIONS Dialog Menu to fix the other commands, but I cant open that menu because OPTIONS is one of the commands that need fixing.
I tried resetting Autocad to default several times, as well as uninstall and install anew.
I cannot think of a reason why this happened, other than my subscription was ending, and I renewed it earlier because it was acting up.
Would greatly appreciate any insight on this, as I'm growing pretty frustrated and the support staff I contacted so far was not helpful.
0 Me gusta
Responder
Soluciones aceptadas (1)
563 Vistas
7 Respuestas
Respuestas (7)
maxim_k
Hi @rb4767 ,
Please specify AutoCAD for Mac version you are using and macOS version installed on your Mac.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
rb4767
macOS Monterey version 12.4
Autocad 2024; says product version U.61.M.182
0 Me gusta
wei503
Does it work if you type a underline before the command, for example "_mtedit"?
Wei Ma
AutoCAD QA Manager
0 Me gusta
maxim_k
Hi @rb4767 ,
Can you share screenshot of the command window when you are trying to use one of the commands you mentioned in your initial post?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
rb4767
@maxim_k This is what it looks like. Hope it helps; let me know if I can provide anything else.
0 Me gusta
rb4767
No, it does not (see reply to maxim_k providing a screenshot).
0 Me gusta
rb4767
Solución aceptada
I was able to solve it by deleting the install folder (Library>Application Support>Autodesk) completely alongside uninstalling. When installing again, the problem wasnt there anymore. Im unsure why this worked as opposed to resetting to default or uninstalling without retaining preferences but oh well.
0 Me gusta
