Old blocks in acad 2020 LT
e_jonkman
e_jonkman
Question
My old blocks from Acad 2004 don't work in Acad 2020 LT
what is the reason and how can i fix this
The attribute are gone, in block editor they are visual but after saving not
maxim_k
Welcome to Autodesk Forums!
Hi Eric,
Do you use "Annotative" property in attribute definition(s)?
If yes, then check current annotative scale at the moment when attributes are not visible.
Or maybe you marked attribute definition(s) as Invisible (look at Misc section of attribute definition inside Block Editor).
You can also attach drawing with one of your problem blocks here, I'll look at it.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
e_jonkman
Hello.
This is one of the 300 blocks
pendean
Community Legend
Community Legend
You have to come to the website, reply to a message, to be able to post files.
maxim_k
Eric,
in order to be able to attach drawing, you have to use WEB version of the Forum. You cannot attach files when you reply by email.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
e_jonkman
Hello this is one of the blocks
maxim_k
There is no attribute definition inside block you attached.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
