Hi all,
I was wondering if it was possible to write a string of Mtext like an excel equation and leverage the (Field-Objects-Object) to have the information in the equation dynamic??
ex.
Sum=(object 1 + object 2)
where object 1 is a hatch area of 300sf identified through the field function
and object 2 is a hatch area of 100sf identified through the field function
if object 1 were to change in dimensions the formula would update automatically.
Thank you
Hi @chloeleyba8NWHJ ,
This kind of complex field can be built quite simply in AutoCAD for Windows, but in AutoCAD for Mac you cannot use fields inside Formula field.
>>>HERE<<< I described a workaround for AutoCAD for Mac. You can try it.
maybe this thread will provide you with the answer
Fields formula for multiple areas - Autodesk Community - AutoCAD for Mac
