Missing complete menu toolbar for Autocad 2015 in Mac OSX
Message 1 of 31
Hi, I downloaded Autocad 2015 in my MAC OSX and as you can see in picture below, I am missing the complete menu tool bar, so can not do anything.
I tried CMD+1 and CMD+0, but nothing happens. Please help me!!!!
Thank you
Sophie,
Accepted solutions (4)
Replies (30)
Message 21 of 31
maxim_k
How to find CUI files inside AutoCAD application folder:
Go to Applications -> Autodesk -> AutoCAD 2015 folder, right-click on AutoCAD 2015.app and select "Show package contents", than navigate as showing in screenshot:
 How to find roaming folder:
Go to Library folder inside your Home folder, than navigate as showing on screenshot:
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 22 of 31
Dear Maxim
Ok I have found the correct folder ( screenshot )
and I have download the zip file autocad 2013.
What can I do now ?
By the way I have download the autodesk folder for the Library and I have put this folder in to my Library ( See the screenshot )
Alessandro
Message 23 of 31
maxim_k
Hi Alessandro,
- You don't need zip file from AutoCAD 2013, because you are using AutoCAD 2015. So you need to copy .CUI files from Resources folder inside AutoCAD 2015 application folder which you showed on the first screenshot.
- Now about the place you need to copy these files to.
It is "Support" folder inside "~/Library/Application Support/Autodesk/roaming/AutoCAD 2015/R20.0/enu/" folder.
Do you see tilde (~) symbol before Library folder? This means that I mean Library folder inside your HOME folder, but not in the root of your Mac local drive.
In order to get in Library folder inside your HOME folder follow these instructions:
http://osxdaily.com/2016/12/12/show-user-library-folder-macos-sierra/
see "Accessing User Library in MacOS Sierra" section
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 24 of 31
Hi Max
I'm sorry , this is my situation folder and there is not roaming folder in ~/Library/Application Support/Autodesk/
ther is something wrong that I do ? or there is another Library folder ?
Alessandro
Message 25 of 31
here is also this folder libraria\autodesk\roaming\autocad2013\r19.0\enu\...
why is autocad 2013 ?
I have download the student 2015 version ( Autodesk_AutoCAD_2015_English_Mac_OSX_R1.dmg )
Schermata 2017-04-10 alle 19.31.03.pngSchermata 2017-04-10 alle 19.31.42.png
Message 26 of 31
maxim_k
On the screenshots in your last post you again show wrong Library folder.
As I wrote before, you need to access Library folder inside your Home folder (User Library):
Accessing User Library in MacOS Sierra:
- From the Finder of Mac OS, pull down the “Go” menu and hold down the SHIFT key
- Choose “Library” from the drop down list:
You probably have forgotten that you have copied these files yourself previously:
https://forums.autodesk.com/t5/autocad-for-mac-forum/missing-complete-menu-toolbar-for-autocad-2015-in-mac-osx/m-p/6998105#M25867
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 27 of 31
Hi MAX
thanks for your help. I will try again but anyway , I have cancelled all autodesk files and re-installed again and than I have post my message so , supostly the files was directly installed form autodesk dmg.
There is no Library folder on the showed menu ( see the screen shot ) Schermata 2017-04-11 alle 22.35.07.png
Message 28 of 31
ok I have found the Library folder trough the command "go to folder " : ~Library
I have copied the file MenuGroup.cui in to the folder support of ~/Library/Application Support/Autodesk/roaming/AutoCAD 2015/R20.0/enu/support ( see the screenshot ) , then start autocad but dosent work .
MAybe I have to copy some other file ?
Or maybe I have to cancel the file menugroup.cui from the original folder ehre I have found it  ( autocad2015/content/resources) ?
Message 29 of 31
Schermata 2017-04-11 alle 22.53.39.pngSchermata 2017-04-11 alle 22.59.58.png
Message 30 of 31
Now I have copy all .cui files from the original folder resources in to the Library folder Support.
I will restart my mac and I will try again and let you know if autocad work.
thanks
Message 31 of 31
YESSS !! I have finaly resolved with the procedure described in the last 3 steps.
Many many Thanks Max !!
