Good evening,
I cannot found the materials editor, why?
This is the first time that I work on MAC, on Windows I have no problem to edit materials because I only need to click on the chosen material then on the pencil icon under the name, but on MAC I cannot do this!
Can somebody help me?
Really thanks
Solved by maxim_k. Go to Solution.
Following up on your thread, were you able to find a solution? Or a workaround?
Did any of the posts in the thread help with your issue?
Please post back in the thread if you are still having an issue with AutoCAD or Select Accept as Solution for the post’s that helped.
Thanks for your time.
I have also problem about material editor in AutoCAD for mac. I can't change the size of material. There is no appearance editor.
Please tell us anyone who knows how to edit materials in AutoCAD 2017 for mac. thanks..
Why can you not edit material? Even as little as change a color in AutoCAD Mac 3D, you cannot edit any material......
I was going to purchase a license, but if you are saying that it doesn't allow in CAD for Mac at all then I won't buy it.
Brandon
