AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Materials Editor in AutoCAD 2017 for MAC
6 REPLIES 6
1928 Views, 6 Replies
Good evening,
I cannot found the materials editor, why?
This is the first time that I work on MAC, on Windows I have no problem to edit materials because I only need to click on the chosen material then on the pencil icon under the name, but on MAC I cannot do this!
Can somebody help me?
Really thanks
6 REPLIES 6
maxim_k
Welcome to Autodesk Forums!
Materials Editor is not available in AutoCAD for Mac, furthermore you cannot use RENDER command locally in 2017 version, only Cloud Rendering avaliable in AutoCAD for Mac since this release.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Emmsleys
Following up on your thread, were you able to find a solution? Or a workaround?
Did any of the posts in the thread help with your issue?
Please post back in the thread if you are still having an issue with AutoCAD or Select Accept as Solution for the post’s that helped.
Thanks for your time.
Sarah Emmsley
Technical Support Specialist
in reply to: Emmsleys
I have also problem about material editor in AutoCAD for mac. I can't change the size of material. There is no appearance editor.
Please tell us anyone who knows how to edit materials in AutoCAD 2017 for mac. thanks..
maxim_k
Hi Mark,
You cannot edit materials in AutoCAD for Mac, there is no Material Editor in it.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
in reply to: maxim_k
Why can you not edit material? Even as little as change a color in AutoCAD Mac 3D, you cannot edit any material......
I was going to purchase a license, but if you are saying that it doesn't allow in CAD for Mac at all then I won't buy it.
Brandon
pendean
AutoCAD for Windows only Boss if you need AutoCAD's rendering and materials editing features https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/AutoC...
and https://support.apple.com/en-us/HT201468
