Loft tool has "Cross sections only" option locked on.
a00829556
Observer
a00829556
Observer
Observer
I am trying to use two CLOSED, parallel and level splines to make a lofted volume. I have tried to turn off the "Cross sections only" option, changed the lofting settings, closing the splines (they are confirmed to be closed), and reselecting the volume mode; it repeatedly makes a surface as can be seen in the last image.
I tried to use the loft tool on a previous set of splines successfully used to make a solid and it still does not work. How can I make a solid with Loft??
Resulting loft surface with cross sections onlyResulting loft surface with cross sections only
maxim_k
Hi @a00829556 ,
Please verify that LOFT command has Solid mode enabled at the beginning of the command.
Plus - the splines geometry can case LOFT command to create surface instead of 3D Solid.
Can you share your drawing or part of it here? I'll look at it.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
a00829556
Observer
Observer
Yes, I have selected solid loft multiple times and it refuses to change from "Cross sections only".  The whole drawing is enclosed, thank you 🙂
maxim_k
Hi @a00829556 ,
I have no problem creating a 3D solid with the LOFT command (sections only) in your drawing:
See attached drawing.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
alina.balkanskaia
@a00829556 Hello, nice to see you in Autodesk Community! Was the @maxim_k answer helpful for you? If yes, please, mark his answer as the solution. Otherwise, please, post more information here!
Alina Balkanskaia
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
