12-09-2022
10:50 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
12-09-2022
10:50 PM
Loft tool has "Cross sections only" option locked on.
I am trying to use two CLOSED, parallel and level splines to make a lofted volume. I have tried to turn off the "Cross sections only" option, changed the lofting settings, closing the splines (they are confirmed to be closed), and reselecting the volume mode; it repeatedly makes a surface as can be seen in the last image.
I tried to use the loft tool on a previous set of splines successfully used to make a solid and it still does not work. How can I make a solid with Loft??
Resulting loft surface with cross sections only
Etiquetas (5)
Etiquetas:
- Etiquetas relacionadas:
loft help
Loft issues
Loft tool
Solid modeling
Solids creation
