Lock Zoom Area
Lock Zoom Area
Lock Zoom Area
Hi, is it currently possible? or can I request feature addtion for locking Zoom location.
e.g. editing a block in editor then saving / exit. you need to then zoom extent then zoom back to area you were working on. Is it possible to Have like a pre-set zoom location so automatically back to where you started.. similar to Edit in place?
Tom
maxim_k
Hi Tom,
I cannot reproduce the issue with blocks in my drawings - every time I exit from Block Editor I always find myself in the same place where editing began.
Do you move objects inside block when you edit it in Block Editor?
Can you illustrate somehow the problem? Maybe with screencast?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Hi Maxim,
Please see screencast - http://take.ms/olDwn
(i was trying to fix the Array at same time) so if you watch first 12 seconds then skip to 1min 30 sec
 you can see what i mean.
Tom
maxim_k
Hi Tom,
Sorry, but http://take.ms/olDwn%C2%A0 "Not found" on my side:
EDIT: Have found the way to open it. Will look at your screencast.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
maxim_k
Can you attach the drawing from screencast? Or just a part of it with array you are trying to edit?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
please try SCREENCAST LINK
Not sure why the post changed the link address.. I cant share the main file at present as it has sensetive data on it. I'll try find another example which can be shared.
Tom
maxim_k
Just erase everything in the drawing except the array and use Purge ALL command.
Or you can send the drawing to my email:
[email protected]
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
