Lines visually do not align with radius (fillet or not)
karolis88KTZ
Observer Observer
Message 5 of 11
karolis88KTZ
Observer
Observer
AutoCAD LT 2023 (MAC) on a MacBook Pro 2012.
Lines and radiuses do not align visually although they are "continuous". Radiuses seem to visually drop down by a pixel. Tried on two monitors with variable resolutions. Arc & circle smoothness value doesn't seem co have any effect either.
Thanks.
Replies (10)
Message 1 of 11
karolis88KTZ
Observer
Observer
Thanks.
Message 2 of 11
RobDraw
Are you telling us Windows users to stay away from Mac because of this?
Rob
Message 3 of 11
karolis88KTZ
Observer
Observer
I am sorry, are you saying this is a MAC based issue? I didn't have this issue when working on an older version of AutoCAD on a different MAC computer.
Message 4 of 11
RobDraw
I am saying that you are in the AutoCAD for Windows forum. There's a different one for Mac.
Rob
Message 6 of 11
maxim_k
Hi @karolis88KTZ ,
Please specify the exact Mac model you are using and macOS installed on your Mac.
Do I understand correctly that you are using an external monitor?
Is it 4K?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 11
wei503
This is a known issue and we are working on fix.
Wei Ma
AutoCAD QA Manager
Message 8 of 11
juemin.yuan
Hi @karolis88KTZ
I guess your graphic card is NV card. Please try to set the sysvar 2DRETAINMODE to off, it may resolve your problem.
Message 9 of 11
maxim_k
Hi @karolis88KTZ ,
I tried to set 2DRETAINMODE=0 as suggested by @juemin.yuan on a MacBook Pro with Nvidia graphics card and that did the trick.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 10 of 11
karolis88KTZ
Observer
Observer
So no solid solution so far?
I had a trials version and it has ended, so I don't know what to do as I wanted to subscribe.
It is really bugging, when you always see a fault in your drawing. So I do not want to invest if in it if there is no solution.
Message 11 of 11
pendean
Community Legend
Community Legend
@karolis88KTZ That is exactly why fully functional trial versions exist: it appears you need to seek out a better solution that meets your exact needs elsewhere.
Here is a list of alternate CAD solutions to explore if you need it https://www.google.com/search?q=alternates+to+autocad+for+mac
