AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
JPEG Image missing in AutoCAD for Mac DWG
8 REPLIES 8
Message 1 of 9
1093 Views, 8 Replies
I insert Jpeg image, when I send it to my colleague (or sometimes open it myself) the images are missing. There is also no Bind option when I right click on the Image in Xref panel. I tried to do Attach, doesnt work either...
@Anonymous Topic Title has been edited by Community Manager, @Tiana_Y, for easier findability.
Tags (1)
8 REPLIES 8
Message 2 of 9
imadHabash
It's normal AutoCAD behave since you don't send also the images itself with the CAD drawing file . you can try ETRANSMIT (Command) . >> Click <<
Imad Habash
Message 3 of 9
pendean
Message 4 of 9
in reply to: pendean
It says "Unknown command". Im using 2021 CAD, so it doesnt even recognise INSERTOBJ command.
Message 5 of 9
dbroad
What OS do you use?
Architect, Registered NC, VA, SC, & GA.
Message 6 of 9
in reply to: dbroad
MAC OS Catalina, 2021 CAD. I used to do Bind in previous CAD versions, cant find it on 2021. Thanks
Message 7 of 9
pendean
You are in the wrong forum (WinOS only). MAC versions have a dedicated forum over here https://forums.autodesk.com/t5/autocad-for-mac/ct-p/4051
Let's get your post moved over there, I suspect you are totally out of luck and need to send over the raster images to the users as well.
Message 8 of 9
maxim_k
Hi @Anonymous
Image Binding has never been available in AutoCAD for Mac. And you cannot "bind" raster image on Mac as you can do on PC, because OLE technology is OS specific and is not supported in macOS.
So the only solution is to insert images as xref and pass them along with the drawing, preferably using ETRANSMIT command
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 9 of 9
in reply to: maxim_k
Thank you very much!!
